Energy Suspension End Link Bushings installed!!!!
#245
Originally Posted by XBMutha
Does anyone actually drive their cars to the limit to test it out for sure?
I know when I push my car it does understeer. When I get off the throttle the back end of the car comes around.
Your classes may have taught you everything, but what I say I have done. I have been driving hard for quite some time. I built and tuned my last car, where there is little to no aftermarket. I also drove the living crap out of it.
#246
I also see that you have a 22mm rear sway. Do you get alot of lift off oversteer with that?
I also know the limits of my car pretty good. I like to push it every once in awhile.
I drove the living ____ out of my old car, to learn how to drive. I don't really drive the Scion as hard, because it is still new. As far as I'm concerned to really drive the car it needs to be lightened and I don't want to gut it.
#248
Originally Posted by driftersil80
Does it matter how you put in the parts? Because I think i put one of the 2 middle washers and a bushing on backwards....
#249
OK im kinda confused....what do you need the grease for? i just ordered these
http://store.summitracing.com/partde...0&autoview=sku
are these "gresable" or "non gresable"
anyone know the diff? what i ordered? how to install if greasble?
thanks
thanks
#250
#251
I don't really need to write this, but I'm going to anyway.
I have nothing new to add to this thread other than this mod did wonders for my handling and absorbing the many bumps that are found in my neighborhood. The "clunkiness" is gone when hitting a sharp bump/pothole. Even with my EasyStreet front struts, it's nice and tight and clunk-free after the addition of these bushings.
Thanks for taking the time to put this thread together.
#252
#253
Finally did this today... learn from my mistake. Loosen each side a little bit at a time. Go all at once and you are liable to get your index finger smashed between the top bolt of the stock mount and the drive shaft. There is so much tension that it is very difficult to remove your finger.
#256
Originally Posted by TheTintBox
This mod is a must if you already done rear sway,springs,shocks and chassis brace. Now I feel my suspension is perfect
