floating front end huh what???
so yeah going around the clover leafs on and off the highways say around 50 mph my front end feels like its floating i thought sticky tires helped prevent that type of things from happening
see my profile for my list of mods
any advice to improve my traction around the clover leafs
or do i need stiffer springs as in TRD's i'm not looking to go any lower from NF210's which i have now
"Floating"? Thats a new one on me. I hate it when it wont steer or skids in a straight line. I usually take off/on ramps from 45+, sometimes needing to slow to merge onto the highway or interstate.
Yup, that's a classic cloverleaf - we still have some of those left here.
Only 'floaty feeling' I've gotten on my box is when I let the tires get to a lower pressure than the box likes. Get's very unsure of it's direction then.
Sounds like spring/shock/strut upgrade time, Johnny!
Tom
Tom
Really? Wow.
Here's a current Google Earth shot of MY exit from I-5 (about two miles from here). It was built in 1956, and I watched it being built when they put the freeway through town.
Tom
Tom
we have interstates that go straight through, none of that stuff, ours are 20 - 30 years old tops, the town I live in, the main drag didn't get paved until 86, it was just straight dirt roads
well i do have quoted from my profile via copy and paste
so yeah its pretty topped out with improvements
Originally Posted by ScionLife Member Profile: duck_dodgers_24_5
dc strut brace, poly endlink bushings and swaybar bushing, trd rear frame brace, progressive rear beam stiffener tanabe nf 210, trd struts and shocks one ton garage rear shims gt spec front frame brace and TRD (RH Evolution GT5) 42mm offset (tire weight 41lbs) - HANKOOK TIRE VENTUS V4 ES H105 215/35ZR18
I forgot you had all those goodies on your egg, Johnny.
I honestly can't think of too much else that would give you appreciable help. There might be some tiny amount of gain with some really serious bits and pieces, but nothing really all that great without tearing the whole bottom out and rebuilding it as a race car.
Don't really want to do that.
Tom
Tom
its cool i just have to learn the limits of the car :D
i am thinking about getting a C-one under panel for my car next year to help with it a bit and to improve my under body dynamics and improve fuel economy :D
i always love improving me fuel economy with all these nice aftermarket parts and yes they do work
I have gone trough that too. the weak link in your setup are your springs. I suggest going with Megan springs and adjustable tokico struts. Which is a very good combo unless you are really driving on rough roads. Or tein ss adjustable coil overs which are a bit softer. The rest of you upgrades look really good. I can tell you from experience that these two are the best options for the type of driving you are describing.
You can go with TRD but it will be a slight improvement over the stock springs. Your car will also sit much higher in the front with TRD springs (as you currently have the NF). The goldline has an ok spring rate but it sits fairly low and I prefer a higher spring rate (when going down 2.0”+) so that I do not have to worry about bottoming out. It has a ratio of 1.09:1 (back to front), which maintains the original split. The Espeilir is a good compromise as far as the drop as well as the spring rate. Unfortunately the Espeilir has a ratio of 0.88:1 (back to front), which adds to under steer.
Keep in mind that the original spring rate Front to back was 148 to 160 that is a ratio of 1.08:1 back to front which is one of the reasons that the XB is fairly responsive, as the higher spring ratio helps to balance the car by cutting down on under steer. Your current setup with the NF has a ratio of 1.19:1 back to front an even higher ratio to keep responsiveness.
Alas the low overall spring rate of the NF is a problem in itself as you have discovered. Essentially the NF is a good choice if you are not going at higher speeds. Cause as you encounter uneven surfaces at higher speeds the momentum created by the higher speed drives up the frequency of the Bump encountered and as this frequency surpasses that of your spring you will start to notice float, which is essentially the inability of the spring to match the frequency of the encounter in one cycle (down and then up only once). So the Nf spring has to go through more than one cycle to match the frequency. Sorry for the overly long and boring explanation.
Now finally, the Megan springs have 0.82:1 ratio back to front, which normally would not be the best for responsiveness. But as the spring rate increases the overall responsiveness of the car increases while low speed driving 40mph and under will seems a little sluggish as springs with higher rates are made to come alive from midrange speeds. Be forewarned though that you must get adjustable struts to match the spring frequency otherwise you will bounce.
Tanabe NF210 1.7" 1.2" 118 140
TRD 1.0" 1.0" 163 176
Espelir ASD 1.57" 1.77" 179 157
Gold-Line 2.0" 2.0" 170 185
Megan Racing 2.0" 1.75" 280 230
