Front struts
Front struts
Ok is it just me or in every how to I see no one is using a spring compressor to pull the top hat off of the struts.. is ther that little presure on the hat? I understand with lowerd springs there would be less pressure but the stock ones have to have quite a bit and I would expect to loose the arm holding the impact wrench when that nut came loose. let me know Im doing springs early next week.
Wagonistas
the scion springs are not under much pressure. Just lay the strut on the gound with your foot on it, and spin the nut off the top with the impact gun. It will pop maybe an inch or two. Its really not that big of a deal since the spring and hat are going to go towards the impact gun, and the strut is going to go the other way. It "might" be dangerous if the strut was standing up on the ground and you blast the nut off. Then it will probably take off your nose. Ive done 19 installs as of this writing, and im still alive. (typing this from a hospital bed). :D
hmmm..I seem to remember someone getting hit in the chin.......
Wagonistas
thanks guys for all the info I figure if I stand on the spring at the end where the hat is the strut will pop out the other side.. Im gonna point it at my neighbor..lol I have in the past done some "Hairy" things... before you take the strut out of the car compress it by jacking under the control arm.. then use heavy duty zip ties.. 4 of them and strap them as a friend bounces on the bumper a little...yea not the safest idea.. and at some point you have to take those zip ties off.. now thats fun you dont wanna leave a compressed spring thats held with zip ties laying around your garage do ya?
I just loosend the nuts before removing the struts then pushed down on the hat as my wife finished removing the nut. I'm a big guy so it was no problem. This is the only car I would try it on. When I put Eibachs on my mini van it could have killed me without spring compressors!
I agree though, a wife in the garage can be VERY scarry!
ken
ken
Here's a tip...
Wrap the whole thing in a sheet and tie it up to make sure it's snug and won't open. Then, cut a whole just enough to unscrew the bolt on the top. Then, all you have to do is keep unscrewing until it pops. That way it will pop off in the sheet... :D
you guys are really making too big a deal out of it. ive done 19 scions. its no big deal.
(j/k) :twisted:
Randy's right.it's no big deal.
Originally Posted by Jester
Here's a tip...
People, be smart about it.. Don't stare at the nut and think nothing is going to happen. Don't point the nut at any living creature or anything of value. Be smart about it, wrap it, point it else where, its simple.
(j/k) :twisted:
Listen to Randy.......he knows more about this then anyone......you WON'T die.
the strut and spring only "pop" apart by 6" or so. NO BIG DEAL!
airmankevin1
02-14-2018 01:23 PM
anarvan
10-31-2003 01:14 PM
