Hotchkis Coils Problem!!
Old 08-24-2004 | 09:05 PM
Nick's Avatar
Default Hotchkis Coils Problem!!
Just wondering if anyone else has them installed. Does the rear sit lower than the front. Cause mine does. Thanks Nick
Old 08-24-2004 | 10:46 PM
xBMNx
Guest
Posts: n/a
as far as i know there suppose to....the front is a 1.5 to 1.6 in the front and 1.7 to 1.8 in the rear
Old 08-29-2004 | 05:17 AM
DGTLLVR's Avatar
Well it should sit level. When you installed them you might not have sat the springs on the struts properly, I would check it out. Is it making any noise when driving, cornering, or going over bumps?
Old 08-29-2004 | 05:29 AM
JdMBboFSD's Avatar
Default ........
agreed.......check that .......
Old 08-29-2004 | 06:15 AM
Guest
Guest
Posts: n/a
the first generation of Eibach springs were like that. The front was higher than the rear, so you this is sometimes normal. Might want to move to another brand of spring if your not satisfied.
Old 08-29-2004 | 07:53 AM
brownbanana's Avatar
i know the hotchkis springs for the 03+ corollas had the higher drop in the rear than the front.
Old 08-30-2004 | 03:15 AM
neckbonenick's Avatar
I'll be installing some on my box this thursday. and I'll let you know how it goes.
Old 09-03-2004 | 01:49 AM
got the rears installed today, before i ran out of sunlight. My work is closed for the hurricane tomorrow so I will let you know how it looks then. I think I will make a separate post for Hotchkis springs installed.
Old 09-05-2004 | 03:12 PM
I installed the fronts on Monday and made a new post
https://www.scionlife.com/forums/viewtopic.php?t=26347
Old 09-10-2004 | 10:41 PM
WileECoyote's Avatar
my hotchkis springs fit well, and are level.
They drop more in the rear because it sits higher in the first place.
Marvelicious
05-01-2015 08:00 PM
djcezile
04-23-2015 06:46 PM
daniinpitt
04-04-2015 08:07 PM
carid
02-12-2015 11:54 AM
TheTripleC
01-04-2015 06:46 PM
Quick Reply: Hotchkis Coils Problem!!
