Hotchkis Sway, Eibach Pro Kit, Monroe Sensa Tracs install
What order do you do this install? All at same time of course, but install the struts, then springs, then sway bar? On the rear i would assume it is the same...Should make the box ride better!
I would remove the front struts, remove the front sway bar, install the new front sway bar, then the front struts (new springs), then the rear springs and rear sway if used. I have the hotchkis sways and highly recommend a lift for this job if available. Clearance for manuvering the front bar out and in is a bit annoying and much easier on a lift than on the floor on stands.
TheTripleC
01-04-2015 06:46 PM
TheRedBox
31
12-02-2003 04:53 PM
2fixA
10-06-2003 05:01 PM
