How many aligned after lowering - What did you find
I lowered using tein basic coilovers about 1.8 - 2.1 somewhere in there...
My rear wheel's toe, WHAT I WAS TOLD, is now in. too much...
XA owners - did you find the same with your rear wheels if you got an alignment.
Did they do a centerline or thrust alignment?
Did you have the back wheel or wheels corrected.
Mine only effected the drivers side back - weird not both wheels
The fronts were a breeze - camber bolt done it.
CONCLUSION: the shop thinks I have a bad factory defect in the rear.
Personally I would go for a second opinion if possible. Did they even try to adjust the rear toe?
I'm waiting untill after I put my TRD shocks in to get an alignment. I can already tell the front wheel camber will need to be adjusted.
thanks
I went to a shop today to check the alignment and they said they could not use the computer's spec for the xa cause it was lowered.
I do I get the correct specs after I lower the car for a proper alignment?
Originally Posted by hotbox05
as far as rear toe it is not adjustable only way to change it is by adding shims.
WINNER!!
Yeah, dropping the car changes the toe in the rear. I watched the techs in our shop do it several times. I've seen the machine. It isn't BS.
-Alex
and doing alignments sucks
seriously, If I didn't do my own (as infrequent as possible)
i would hate to pay for this service (we charge $150+parts)
adding shims to the rear isn't as bad as other cars
at least you can get to the bolts.....
eatcrispycreme2
01-30-2015 03:42 AM
kleecker
01-02-2015 08:09 PM
Besk_one
10-16-2003 07:45 PM
