How much can i drop my car w/out issues..
Ok i got 18" rims w/ 225 40 r18 tires... I was thinkin 1.5 drop .. Also what is a good lowering spring to put on... I dont want it to rub on fenders when i turn... as it is it rubs on inside a lil bit .... i just dont want tons of issues while driving ... bumps.. turning .. etc...
Originally Posted by bumble996
The more you lower it the worse it's going to get on the inside...
Needless to say, my next set of tires will be slimmer.
-THE DON
ok so if i got a thinner tire like 215 or something like that then drop it .. i should be in good shape?? .. or if i kept this tire on and dropped it it would rub on turns only or all around??? im more concerned about just driving and rubbing ...
Well i have 215/40 18"x7.5 rims with goldlines. The only rubbing i get is when i have my steering wheel at full turn. Its really not that bad at all... the ride is very comfortable... as for 225 i hear of so many problems with rubbing issues....
i was thinking about keeping my 225 40 r18 tires and dropping it with TEIN 1.7 front and 1.5 back ... im assuming my only problem would be when i turn and if i go over a bump fast ... am i right ??
Originally Posted by alibuster
I think that it is already low enough. I don't understand why you would want to lower it anymore. Then you would just have problems with bumps in the road.
Godfryness
01-02-2015 11:18 PM
Besk_one
10-16-2003 07:45 PM
