The last Straw
Old 08-29-2005 | 01:00 AM
sciondrgn's Avatar
Default The last Straw
OK well my drivers side Rear Bag from Easy street broke again!! This time The Bag actually came out from under the bag nearly causing my to wreck! Im so mad right now .. Even though Easy Street Worked with me in the past this bag hasnt been on the car more then 2 months .. And this is the new design to boot.. Im calling them tomorrow and raising some heck!!
Who else sells air ride kits other then the EAI style?
Old 08-29-2005 | 01:24 AM
bruceb's Avatar
call phil from fbi http://www.fbirides.com/shopping_sea...cion&cat_idno=
get there brackets and contitech bags!
Old 08-29-2005 | 01:27 AM
bruceb's Avatar
oh yah glad you did'nt wreck man, good luck!
Old 08-29-2005 | 02:19 AM
Spider13's Avatar
Damn that sucks, I am glad you didn't loose it too. I lost one of mine doing 70...with short shocks it was a crazy ride until i could get pulled off the road. If you decide to put them back on...get rid of the 2 bottoms screws in so that the bags can shift in the spring seat. That seems to have made the difference in mine.
Old 08-29-2005 | 03:29 AM
sciondrgn's Avatar
I didnt think about that spider.. We will see what happens tomorrow after I call them.. Ill def call FBI as well
Old 08-29-2005 | 03:30 AM
sciondrgn's Avatar
Also Spider You dont have any problems with leaving them loose like that?
Old 08-29-2005 | 04:05 AM
DUB_BUS's Avatar
Let me tell you sometiming I have been ont the same air ride kit for 2 yr on two difrent xb's and never had a problem. Hve over 10,000on kit no problems. You need to call Oshie at Universal Air product 1-800-864-2470 he is in So cal...tell him big john refered you he is a good friend of mine...
Old 08-29-2005 | 04:13 AM
sciondrgn's Avatar
Ill call them as well tomorrow
thanks dub
Old 08-29-2005 | 04:31 AM
BrianxB's Avatar
that sucks man. I have my old rear Easystreet kit if youd like to buy them.
Old 08-29-2005 | 04:39 AM
sciondrgn's Avatar
Ive got an extra bag sitting here just havent put it in yet.. Im going to call them first and see what ES will do first.. Im going to try what spider said and leave the botom bolts out see what that does and also see what ES will do as far as replacement or refund. Im going to go with the fbi kit more then likely..
Old 08-29-2005 | 12:13 PM
Spider13's Avatar
The only thing you have to watch is jacking up the car. Since the bag can popout of the seat, when you set the can back down you have to make sure everything stays where it belong as you lower it back down....but since the fitting goes through the center its pretty easy. I still think that the design is bad for a sleave bag. it really should have been a regualr bag.
Old 08-29-2005 | 03:00 PM
sciondrgn's Avatar
Ok Cool that should be a big deal I have to do that with my springs anyway to make sure they stay seated in there
Im still going to call fbi on my break and get some prices ..
thanks for yalls help
Old 08-29-2005 | 03:40 PM
sciondrgn's Avatar
Just had a talk with Brian @ Easy Street and Told him of the situation.. he told me that they had problems with the pressure ring coming loose but they have corrected it in a newly designed bag and he told me they have been testing around 400-450 psi and were not able to pop them.. He is sending me two brand new ones and We will give them A go..
This will be the last strike if these dont work..
Old 08-29-2005 | 04:41 PM
Spider13's Avatar
I don't think its a pressure problem. When you lift your car look at the bags. The top is twisted to the front of the car because our suspension travels in an arch. This causes them to stress the very back part of the bag. I'd bet money that hole in your bag was facing the back of the car when it let loose. But I have to call this morning too since I think my compressor is dieing now. So I get to talk to them too.
Old 08-29-2005 | 10:29 PM
sciondrgn's Avatar
yup it was facing towards the rear..
Old 08-30-2005 | 03:35 AM
Sesh1975's Avatar
Just curious as to why you are using a sleeve bag instaed of the donut bags? I know back in the day I had a lowered full size chevy and i ran sleeved bags, they gave out so damn quick.
Old 08-30-2005 | 03:38 AM
FrankenScion's Avatar
My buddy was having the same problems with Easystreet. He finally just switched them out for pancake style bags from Slam Specialaties and hasn't had a problem since.
Old 08-30-2005 | 04:50 AM
Sittin_Pretti_Box's Avatar
I couldn't say it any better. Thats the best thing you can do.
Old 08-30-2005 | 05:21 AM
sciondrgn's Avatar
its because thats what easy street uses for there mounts..
I would love to use regular bellowed style bags..
Im going to give ES one more try.. He told me theyve found the problem with them and they were running 400+ psi to them without blowing so who knows Im willing to give it atry as long as there willing to fork over free bags to try it with..
Ill let everyone know how it works..
Old 08-30-2005 | 05:55 AM
FBI makes mounts for a 2500lb bag... a lot less hassle.
Quick Reply: The last Straw
