looking for in-expensive coilover kit any suggestions?
sup fella's! just wanna ask yall if you guys know anyone that sells
coilover for a good price!!!
tein basics sounds good!
how do the megan racing one's do?
i use the box for daily drive only.i just don't feel low enoungh with the s-techs
and i just read a post! there were some called STD i believe where can i find that???
and i if i were to get the teins what are the recommended height settings?
iam on sportmax 002 high offset not the 0's and they are 16in. 205/50 series.
dropped on s-tech and stock struts.
thankx!
thankx!
I would do something other the Basics. They are a nice quality coilover but don't fo low enough. Look into some K sports or Progress. K sports can be had for around 900 and you get plenty of tuning options with them. Progress are about 700 but no tuning options
you should check out the STD Coil Overs ive installed several sets of them and love them so much that if i wasnt on air i would be running them and they have agreat price for everything you get
Shoot Box_Rod pm he is about to become a distributer for them
Thanks
Lil Dave
Thanks
Lil Dave
Progress is junk. You lower the car, you change your spring rates. They make good sway bars, but their coilover setups are junk.
D2's. Lower the car, keep the spring rate. Raise the car, keep the spring rates. Individual height, damping, and spring rate is a much better way to go, and for around the same price.
D2's give you all the features of Tien SS, but at a fraction of the cost.
Originally Posted by Sciond
sorry dude but you have no idea^^^^ Progress coils work great as I have them for about 70,000 miles.. I looked at the d2's and were not impressed.......
I've ran set ups just like Progress. Where you lower the car, by compressing the spring. Which makes for stiffer spring rates the lower you go.
When it comes to coilovers. You want to be able to adjust height, with out effecting your spring rates and pre-loads.
Lets say you decide to go auto crossing. You're running pretty low on height, and that gives you you're stiff spring rate. NOW after you're first run, you find that you're cutting into your tires from body roll. So for your next run, you lift the height of the car up 1". So now by doing so, you're stiff spring rate, has just been softened, creating more body roll, and less vehicle control. Which results in slower speeds, tire spin, wheel hop, ect.
As far as daily driving on Progress go, fine and dandy. But when you want to put them to good use on a track.... Not gonna help ya.
Re: looking for in-expensive coilover kit any suggestions?
TheTripleC
01-04-2015 06:46 PM
hampton1100
01-02-2015 08:13 PM
JM Auto Racing
12-19-2014 06:36 PM
