LSD installed....
Originally Posted by Grimgrak
Dg can you please tell me with your current "too tall" gears installed what rpm are you at in 5th gear at 60mph?
but i calculated the RPM's to be 2300 @ 60 in 5th.
that well out of the power band of the motor.
i would always have to drop down into 4th just to cruise and move.
Wow thats perfect for me! Where can I get a set of these gears?
in case you missed the it, i never installed the other gears...just the LSD.
from me if you want.
other wise any echo sedan 5 speed.
this is only for a manual transmission.
i warn you you will not be happy with this low of a gearing.
you will have to floor it to build any speed.
take your car out driving, get in 5th gear, let the RPM's drop to 2300.
now floor it and see how long it takes to build up speed.
if you really want the gears let me know..
Is the installation all finished now? Did the TRD final gear set fit right up with your KAAZ LSD? Or u need to replace some other cross gears also?
Looks like the KAAZ LSD u got uses 8bolts isn't it? How about the final gear?
i don't know why you think it won't bolt right up....all of these parts are made for this transmission.
the LSD bolts right up to the stock gears.
why would TRD make a replacement gear for this tranny that wouldn't bolt right in...
The LSD is in and works very well.
it does cause some different driving characteristics in the car. but this is expected when doing such a change in the drive train.
i think he's asking because of this thread he started.
https://www.scionlife.com/forums/viewtopic.php?t=77453
Also would u happen to know your tranny's code#? Since mine is C150N.......
tranny code---C154
plese note some of the gears are diff. and the housing has diff mounting tabs.
i check some info and pics....the best i can remember the LSD used 8 bolts. it bolted right up to the final gear.
What u meant the mounting tabs are on the final gear or the tranny housing? Sorry just to confirm...
So u have a 1NZFE also? If so the C154 tranny housing would bolt right on to my long block?
What I am trying to do is to find out if the C154 tranny off from a xB would bolt right on to my 1NZ-FE long block and get the WHOLE tranny for the LSD....
the mounting tabs on the scion tranny housing are in different locations than the echo tranny housing...
yes the whole tranny should bolt right up to your long block (both have the 1NZ-FE motor)
the scion tranny will have different gear ratios for 4th and 5th gears.
also the final drive of the scion is higher 4.31 (echo is 3.52).
how do you feel about turning 4000rpms @80 mph???
bye bye mpg!
bye bye mpg!
Well... considering I am getting 600km per fill of 40 litres (Don't use until empty for the tank of 45litres), which is about 35 mpg... so I am not too worried about that... I am more curious about if the car will be faster or something... haha
Thanks
Sunny
Thanks
Sunny
the gearing will provide better luanching and be quicker in 1st, 2nd, and 3rd...
you can find a used scion 5sp and just swap the guts over to the C150 housing.
