Monroe owner's opinions
I'm trying to decide about swapping out the OEM rear shocks on my XB for Monroe Sensatracks.
If you can offer an opinion, it would help. I'm just looking for a better overall ride.
Suggestions?
Suggestions?
The stock shocks seem to "hop" when you hit something. Since the spring rate is the same, does the new shock affect the handling at all?
Thanks to all who have already replied. Your comments are appreciated .
Music City Scions
The problem with the rear OE shocks are they don't absorb the bumps. (compress fast enough) The Monroe #5987 will make the ride 110% better trust me. My stock shocks will Never go back on.
I just put Monroes on today! If you only make one mod, this is the one. The stiff stock shocks and short wheelbase make the xB's handling sketchy at times. With the Monroes, most of the annoying bouncy bumps are gone. Freeway expansion joints are much less noticeable. In fact, I started thinking I'd like a softer front suspension to match after about 20 minutes of driving.
I do think it's good to install a rear sway bar with the shock swap. Some have posted the softer shocks will make your box lean a little more in the corners. I put on a Progress bar at the same time I changed mine. The combination of less lean from the bar and less bounce from the shocks make it corner really well.
Music City Scions
Originally Posted by xA_Factor
Originally Posted by jethro_b
That's why we are here. To help everyone get the most enjoyment from their toasters.
I have no idea, but the OEM shocks on my xA seem no where near as stiff as the ones on my xB.
Thing is, the SensaTracs have this 'soft' range in the middle of their travel and then stiffen up right nicely. The OEM xA shocks are the same stiffness throughout their entire travel, so probably wouldn't control the heavier xB as well as the SensaTracs...
Tomas
Tomas
Again,
Thanks to everyone who has responded. I'd really like to improve the quality of the ride. This has been my biggest roadblock to "Lowering" as I think it looks great but am not willing to sacrifice ride quality.
Your opinions have helped .
