Monroe owner's opinions
Old 02-27-2007 | 07:21 PM
  #81
Big_Bird's Avatar
so i have s-tech's they settled to almost 2" like 1.9 or something
so would the monroe rear shocks offer any handling help, or do they just make the ride "smoother"?
also what would the fronts offer? any handling improvement
i dont really mind have a stiff a$$ ride, as long as she handles well, my girl might feal differently though, lol
Old 02-27-2007 | 08:33 PM
  #82
bB2NER's Avatar
Music City Scions
Nothing for handling just smoother ride (read less harsh). Handling you would need a rear sway bar like Progress, TRD or Whiteline.
Old 02-28-2007 | 01:26 AM
  #83
vintage42's Avatar
Originally Posted by Big_Bird
... so would the monroe rear shocks offer any handling help, or do they just make the ride "smoother"? also what would the fronts offer? any handling improvement...
The SensaTrac rear shocks match the OEM Tokico front struts, making a perfect ride. Not too stiff and not too hard. There is no point in changing the Tokico front struts to SensaTrac, as they are about the same.
The SensaTrac rear shocks will not help handling, only the ride. To improve the handling, add a rear sway bar, which makes the car corner with less lean and also makes the steering neutral in hard corners - no over or under steer.
Both the shocks and the sway bar can be installed with all wheels on the ground in the driveway by one person in an hour total.
Old 02-28-2007 | 05:44 PM
  #84
Chiguy_2002's Avatar
Really good information in here!! I am starting to build ideas...lowering springs, Monroe rear shocks, progress swaybar...
Old 02-28-2007 | 09:22 PM
  #85
Robot_Box's Avatar
Originally Posted by bB2NER
The ride will be 100% improved day and night difference. #5987 for under 2 inches of drop and #5870 for 2 inches or more.
what if im running like a 1.7-1.9 drop?
Old 03-01-2007 | 04:41 AM
  #86
bB2NER's Avatar
Music City Scions
use the 5987 monroes.. thats what i used. you will be 100% satisfied.
Old 03-04-2007 | 05:24 AM
  #87
4150's Avatar
This is a great thread! I just took a trip to LA and all the bouncing around caused my daughter to get car sick for the first time ever and throw up everywhere. Desperate for a cure I came here first and with any luck this will take care of the rough ride. I drove cross country in a Camaro SS with a stiff suspension and my daughter never got sick, much longer wheel base though.
Just ordered a set of 5987's from advance auto for 31.99 each with free shipping to my door. I can't wait to get them installed.
This thread is a life saver!
Old 03-04-2007 | 06:20 AM
  #88
Tomas's Avatar
Admin Emeritus
Hope they help - they should.
Tom
Old 03-04-2007 | 06:26 AM
  #89
OldYeller's Avatar
Someone just posted that there is now an actual number for a xB monroe
https://www.scionlife.com/forums/vie...ghlight=monroe
Old 03-04-2007 | 06:34 AM
  #90
Tomas's Avatar
Admin Emeritus
Damn! They doo have one shown now!!!!! :D
I wonder how the Sensatrac xB rears compare to the Echo's?
Tom
Old 03-04-2007 | 06:36 AM
  #91
4150's Avatar
I saw that, I don't really feel like waiting until October to get them though.
Old 03-10-2007 | 05:06 AM
  #92
4150's Avatar
I just put in my Monroes today and it was an easy easy install, took around 20 min and I was taking my time. I didn't even have to jack up the car or drive it up on ramps.
Anyway the new shocks made a big difference, the ride is much much better. For $64 total this was a great mod
Old 03-10-2007 | 05:11 AM
  #93
jonnyd's Avatar
That's great to hear to solidify my plans for the weekend. Just bought the Monroe's on sale at Adv. Auto for $44 so I am eager to now put them on this weekend.
I'm just hoping I can get under there with my 2" drop. If not, back to Wally World!
Old 03-10-2007 | 06:11 PM
  #94
JakAHearts's Avatar
When installing these shocks, how much of the shaft did you guys leave sticking out above the nuts? Could you tighten it too much or too little and not have the shock in the right range to be compliant? This is for an Xa if it matters
Shane
Old 03-10-2007 | 07:40 PM
  #95
Tomas's Avatar
Admin Emeritus
15-18mm
(Only you'll just be using the single locknut instead of two nuts.)
Tom
Old 03-11-2007 | 04:36 PM
  #96
jonnyd's Avatar
Tomas, first off thanks for the great advice and info! You made my install virtually painless and it only took about 30 minutes. It took longer to figure out which pieces to pull off of the old shock then to put the new one on!
Do you or anyone else happen to know if the bolt that Monroe gives you is a lock nut? I'm just concerned since the thread is different and I couldn't use the old ones. Might have to make a trip to Home Depot if needed.
I put on the 5870s and they have definitely improved the ride. I have Goldlines and tended to get beat up on longer trips. My commute is an hour each way so ride comfort is a premium for me.
Old 03-11-2007 | 08:51 PM
  #97
4150's Avatar
I ended up just using some blue loctite on the nut Monore provided since I'm paranoid, so far so good.
Old 03-11-2007 | 09:45 PM
  #98
Tomas's Avatar
Admin Emeritus
It really is a one-time-use locknut that they supply.
Tom
lvlisslvlelissa
Scion xD ICE & Interior
10-13-2023 04:40 PM
Rhymenoceros
Scion xD Drivetrain & Power
07-02-2016 11:12 PM
MRE
02-17-2016 12:26 AM
2014
06-02-2015 04:36 AM
xabiscuits
06-02-2015 02:17 AM
