Monroe Shocks..
Old 10-25-2006, 11:27 PM
  #141
Admin Emeritus
Tomas's Avatar
OK, the 5870s will probably allow you to go a bit lower. The 5870s are not only shorter, but normal installation of them removes that big rubber bump stop at the top of the shock shaft.
They're fairly cheap and easy, so would be worth a try.
Tomas
Tomas is offline
Old 10-25-2006, 11:35 PM
  #142
TheScionChef's Avatar
thanks Thomas i appricate it you are like the tech guru of all i just wanted a gurus opinion on what actual part number so that i do not get the wrong ones.
again
TheScionChef is offline
Old 10-25-2006, 11:52 PM
  #143
RTon20s's Avatar
Thomas is right. Several people have used the 5870 Monroe shocks to get additional drop in the rear on bagged xBs.
There are other shocks from them that have been used, and other recommendations that have been made if you feel like searching.
RTon20s is offline
Old 10-26-2006, 01:07 AM
  #144
xA_Factor's Avatar
I didn't realize you were asking if you could gain more suspension travel with shorter shocks. I thought it was another "which rear Monore shocks lower me more?" question.
My bad.
xA_Factor is offline
Old 10-26-2006, 01:42 AM
  #145
no worries xa factor its my fault for not making it clear enough i guess ... but thanks for the info guys
Old 11-12-2006, 02:37 PM
  #146
Skorpion's Avatar
Anyone running:
Progress Sway
OTG Shims
Monroe Rears
DF210
W/18 rims?
A lot of bottoming out?
Skorpion is offline
Old 11-22-2006, 02:23 PM
  #147
Omega145's Avatar
Im wondering where is everyone getting the Monroe 5987's?
I called Sears and a few other places and they couldnt locate them by that part number or by make/model.
Omega145 is offline
Old 11-22-2006, 07:55 PM
  #148
Admin Emeritus
Tomas's Avatar
See the answer in the other topic where you posted the same question... https://www.scionlife.com/forums/vie...070744#2070744
Tomas
Tomas is offline
Old 04-10-2009, 09:13 PM
  #149
Music City Scions
bB2NER's Avatar
Here is something I just got. Monroe is having a rebate thing.
http://www.northernautoparts.com/?ut...m_medium=email
bB2NER is offline
Old 04-12-2009, 05:59 AM
  #150
ihatemyxa's Avatar
if you think about it, the force from the spring can infact push the stem up a little more if the suspension is loose
ihatemyxa is offline
Old 04-13-2009, 09:12 PM
  #151
lilmanguts's Avatar
Ok im kinda confused bout all the threads about the 5870's and the 5987's.
If your on OEM springs use the 5987's?
if your on lowered springs use the 5870's?
Some say that you only use 5870's if your lowered 2"+ and some say if you are lowered 1"-2". So which is which?
I'm running on Tanabe NF210 on stock struts/shocks. There is a lot of clanking on the front right side every time a pass a bump. Im considering of replacing everything with Monroes. Now, Which would be the best set up for me?
lilmanguts is offline
Old 04-13-2009, 09:33 PM
  #152
burstaneurysm's Avatar
Use the 5987 if you're dropped up to 1.5"
Anything more and go with the 5870s.
burstaneurysm is offline
Old 04-14-2009, 01:08 AM
  #153
Admin Emeritus
Tomas's Avatar
And the correct Monroe/NAPA/Tenneco (all the same) front strut for the xB Classic is the 72245...
Tomas is offline
Old 04-14-2009, 05:45 AM
  #154
lilmanguts's Avatar
Thank you Burst.. and Tomas for the infos. Keep it up and GOD BLESS!
Old 04-14-2009, 09:45 PM
  #155
lilmanguts's Avatar
Hey Tom and Burst..
Follow up question. is there any reason why 5987's and not 5601's? Monroes website recommended the 5601's. Please explain. Thank you.
Jonathan
Old 04-14-2009, 10:07 PM
  #156
Admin Emeritus
Tomas's Avatar
When the 5987s were first recommended Tenneco had not yet come out with ANY shocks for the Scion xB Classic.
The 5987 is intended for the Toyota Echo sedan (same suspension/drivetrain), and as such is slightly softer in it's control of suspension movement.
For extreme "sport" driving they are not the first choice, but for more normal driving in everyday use the combination of slightly softer control AND the variable damping offered by the "Sensatrac" design give a MUCH improved ride.
The 5601s are a little stiffer that the 5987s, and while still being Sensatrac, and offering the variable damping for improved ride in normal circumstances, they are a bit more brutal in very large suspension movements.
With the 5601s, the ride is improved with no loss in control during more "extreme" driving.
For my driving style, the Sensatrac 5987 shocks in the rear and (soon) the Sensatrac 72245 struts in the front should be "perfect."
For someone with a more "sporting" style, the 5601s and 72245s would probably be better.
For someone actually rallying or racing a box, much more serious suspension is needed, rather than components intended for the street.
Hope that helps! :D
Tomas is offline
Old 04-14-2009, 10:26 PM
  #157
lilmanguts's Avatar
Thank you again for the swift and helpful reply Tom..
Since, i like comfort for my 40 mile one-way every day commute to work. I'll probably get the 5987's and the 72245's.
i hope it makes a difference since im on 18" and 35 series tires and the road feel is much harsher. I am even considering changing to 17" and 45 series setup. but i'll try the struts and shocks first.
Thanks again for the info.
Old 04-15-2009, 05:20 AM
  #158
Music City Scions
bB2NER's Avatar
Trust me Tomas when I say "it will be". I have that combo with Tein H techs and couldn't be more happy with the ride quality.
lilmanguts, It will help some but with those 18's it will still be sort of rough. Some 215/40/17's would be great.
bB2NER is offline
Old 04-15-2009, 06:10 AM
  #159
layedoutxa's Avatar
Are Gabriel shocks the same as Monroe? If not, are they equally as good as the Monroes? Because the autozone website lists this:
Gabriel Ultra / Shock/Strut - Rear
For your 2002 Toyota Echo 1.5L EFI DOHC 4cyl
thanks
layedoutxa is offline
Old 04-15-2009, 06:26 AM
  #160
Admin Emeritus
Tomas's Avatar
Gabriel's are likely "as good" as the ones made by Tenneco (Monroe/NAPA) but the shocks we are discussing are their "Sensatrac" shocks with a patented "variable rate" valving that depends on where in it's range of movement the shock piston is.
If the piston is in the "normal" range for an at-rest car, plus or minus a couple of inches, the valving is quite soft to let the suspension absorb all those little shocks from cracks, tar strips, small rocks, etc.
If the shock move OUT of that narrow range of motion, the valving stiffens up and the damping increases to give better control.
I don't believe the Gabriel 69450 shocks have that feature. I'm pretty sure they are just ordinary shocks...
Tomas is offline
Quick Reply: Monroe Shocks..
