My Bagged Box!!! Lots of pics!!!
Old 09-26-2005, 02:00 AM
  #61
Lance's Avatar
hey man check out www.bagginit.com
Nice little site with lots of basic info on airsuspensions.
Lance is offline
Old 09-26-2005, 02:58 AM
  #62
KAD
rebelMan's Avatar
thanks lance, very nice website :D!!!
rebelMan is offline
Old 09-26-2005, 03:48 AM
  #63
KAD
rebelMan's Avatar
hey sittin_pretti
what is that little adjustment at the bottom of the ES struts for? Dampening? Tell me about em please, i don't know much about dampening adjusting etc.
rebelMan is offline
Old 09-26-2005, 03:51 AM
  #64
peabe's Avatar
heres a nice diagram from bagginit.com
peabe is offline
Old 09-26-2005, 04:01 AM
  #65
KAD
rebelMan's Avatar
yea i seen that, thats FBSS right?
sittin u have a 2 port 5 gal tank? How do you drain it, u unbolt it every once in awhile
also, i assume the pressure switch has a wire that runs to the compressor to tell it when to kick on right?
rebelMan is offline
Old 09-26-2005, 05:59 AM
  #66
Sittin_Pretti_Box's Avatar
I couldnt tell ya what that lil **** is for, I'd say dampening? I could care less really, I enjoy the ride of air and its more about being lower than maintaining a smooth ride, but it is still a smooth ride.
Rebel, I have a 2 port 5 gal, I do not have a drain plug. I don't bother with that stuff, never have before, heh.
Sittin_Pretti_Box is offline
Old 09-26-2005, 10:53 AM
  #67
hotbox05's Avatar
if you dont have a drain vavle your tank will rust and your bags and valves will go bad.......you need to empty the water out of any compressed air system at least once a month.
hotbox05 is offline
Old 09-26-2005, 11:03 AM
  #68
KAD
rebelMan's Avatar
thats what i thought... what if you have a water separator, does water still get past it and into the tank?
rebelMan is offline
Old 09-26-2005, 02:54 PM
  #69
sciondrgn's Avatar
Its possible but with a Good setup it wont be as bad
I had Bags on my cavalier for 3 years with a water trap.. same tank / same valves and same bags with no problems..
Some moisutre still gets in but its no big deal to drain the tank
sciondrgn is offline
Old 09-26-2005, 04:35 PM
  #70
KAD
rebelMan's Avatar
you just unplug the fittings and let the water drain out one end right? Do you let it dry out as well?
rebelMan is offline
Old 09-26-2005, 05:01 PM
  #71
sciondrgn's Avatar
yup I just unplug everything take it out and clean it out real good and then let it dry
Old 09-26-2005, 05:23 PM
  #72
crayonBOX's Avatar
that's a way to do it; i usually go under there about every week or so wheni wash and twist the 1/4" drain valve for a few seconds and a good teaspoon of water or more come out...
it worries me that it is a rusty color; but iono, i dont leave the water in there long.
crayonBOX is offline
Old 09-26-2005, 05:25 PM
  #73
KAD
rebelMan's Avatar
it's so worth the easy maintenance
I hope i don't have any problems with the bags when i decide to do it. I only drive like 150~ miles a week...most round trip miles i'll ever do will prolly be like 600~ ... hopefully no blow outs. Maybe i should carry 1 stock rear spring in case a bag blows
rebelMan is offline
Old 09-27-2005, 04:44 AM
  #74
LilBlkBox's Avatar
Water will get past a water seperator. Having moister in the system is ok unless you have freezing weather. These valves are made for water or air. My setup would always freeze in the morning and wouldnt lift. Sucked!
Bags are fun, but eventually get old.
The setup is sweet though and I love the wheels.
Also, what are the plans for the s10? Is that stock floored? And.. how much of a BD does it have.
LilBlkBox is offline
Old 09-27-2005, 11:32 PM
  #75
our S-10 just has the traditional BD done to it. Has a 3 and a half inch body drop. Next plan is to finish more of the body work, shave the handles, 3rd brake light, hood squirters and antenna. Then do paint and work on the interior.
Old 09-28-2005, 02:04 AM
  #76
Spider13's Avatar
I've crippled home with only one rear bag twice now. Since the rear axle is solid, its not to bad. The first time I drove almost 60 miles with one bag, its a little low on that corner, but as long as you take it easy you should be fine. Now blowing the bag at 70 is the scary part.
Spider13 is offline
Old 09-28-2005, 03:48 AM
  #77
KAD
rebelMan's Avatar
>_< please tell me that was with the ES rear bags and not SS or Conti's
rebelMan is offline
Old 09-28-2005, 02:39 PM
  #78
Spider13's Avatar
yep it was ES.
Spider13 is offline
Old 09-28-2005, 04:35 PM
  #79
KAD
rebelMan's Avatar
thank god
rebelMan is offline
Old 05-30-2007, 10:37 PM
  #80
Team Echo
hotboxn's Avatar
anyone have a diagram for wiring up with air line running to each bag individually?
hotboxn is offline
Quick Reply: My Bagged Box!!! Lots of pics!!!
