N-Brake NA-Performance Brake Pads Intalled! PIX! Update 5/5
I got the pads in the mail on Saturday (love Saturday FedEX) the weather has been crapy since then and today the weather cleared up, so it was install time.
I got the pads from Cockpit Auto Sports www.cockpitautosport.com Great people and great product
I got the "PINK" pads which are the race compund pads. They also make a street pad, but I wanted to have the more agressive pad.
Once I installed them I took the car for a test spin and immediatly felt a difference. The braking was much more responsive. If I pushed the brake pedal down about 3/4 of the way the tires locked up! Stoping the car in general felt better and more firm. Im sure once the pads break in they will fell even better ... Ill keep you guys updated as I put more miles on the car!
UPDATE 5/5/05
After about 125 miles of driving on the pads they have improved very much since mile 1. The brake pedal feel much better and you don't have to apply as much pressure to stop the car. I have driven the car in everything from stop and go to 80mph on the hwy and the brakes all around feel much much better. There is no brake fade and there is no brake noise. These pads were a major improvment over stock!
First Here are the pads and the box
Factory pads still installed
N-Brake NA-Performance Brake Pads installed in the caliper
Caliper and N-Brake NA-Performance Pads mounted back up
Another shot!
Eveything back together!
UPDATE 5/5/05
Another shot!
Originally Posted by LavaBox_v1
Nice!! ... I sold my 929 just befor winter ... Im gonna pick up a CBR1000 in the next month or so ...
Let me know how the N-Brakes hold up w/ the stock rotors. A buddy of mine wants me to try Cobalt brakes.
I had Cobalts on my Honda and they were awsome ... BUT I also has Brembo OEM X-Drilled/Slotted Rotors, Goodridge Brake Likes and ATE Super Blue Brake Fluid ... But the cobalt pads held up very well and did not have any fade during hard braking ...
Ill keep you posted on these N-Brakes ... so far they have been excelent ... No brake fade and very responsive braking ...
We have the same caliper, I just didn't use the metal plate that goes on the back of the pad ... I only used the metal plate on the inside pad where the brake cylinder presses against the pad ...
I think as long as you need the metal bracket on the side with the caliper piston you should be fine ... From what I have learned its just used as a spacer shim and to protect the pad from the caliper piston ... Your factory caliper only has a piston on one side so as long as the pads fit snug on the opisit side you should be fine ... Which in this case the N-Brake pads fit nice and snug with out the metal plate so I decided not to use it ... If I feel after time there is a problem with the pads then I will put it back, BUT so far there has been no problems and better braking!
https://www.scionlife.com/forums/vie...218&highlight=
visit this post for prices & even brake packages from the sponsored sales forum. Thanks for your inquiry guys.
Team Sushi
How's the noise? I'm not really sure, but I've heard that high performance pads or rotors will be more noisy/squeeky. . . but it wasn't exactly from a qualified source.
