OEM hub bolt size?
Old 02-14-2008 | 02:13 PM
Boxer_Rebellion's Avatar
Default OEM hub bolt size?
Hi all- I put on some OTG 10mm hub shims a while back that came with extended bolts and threw away the stock ones... but now thinking about getting zero offset wheels and need more clearance. Anyone know the exact specs on the stock bolts? Is it true that you can get them at hardware stores?
Thanks in adavnce, Donovan
Old 02-14-2008 | 06:50 PM
burstaneurysm's Avatar
Not sure what size they are offhand. Make sure you get a grade 10.9 bolt (metric equivalent to SAE grade I haven't found a ton of hardware stores that carry the high grade metric stuff though.
Old 02-15-2008 | 12:52 AM
jct's Avatar
jct
hit up a junk yard and take some off a echo
rain7905643
03-14-2015 12:48 AM
kleecker
01-02-2015 08:09 PM
arinvolvo
01-21-2004 11:40 PM
TrEyHoLyO
01-14-2004 05:13 AM
Quick Reply: OEM hub bolt size?
