ok i lowered my box now...
Old 03-14-2005 | 04:01 AM
scion04xb's Avatar
Default ok i lowered my box now...
now its making a grinding noise when i turn to the right its a metal on metal and it does not do it if im going slow and its not a bad its a tinny type metal on metal not a bad noise any ideas what it is??????
Old 03-14-2005 | 04:02 AM
pharynx's Avatar
I hear that noise when i turn to the right also However i'm not lowered, just 17's.
Old 03-14-2005 | 04:06 AM
scion04xb's Avatar
hum i thought about its the stearing pump but that cant be it
Old 03-14-2005 | 04:41 AM
LiquidXB's Avatar
I am on TRD springs with 17's and i have the same problem....
Old 03-14-2005 | 05:34 AM
pharynx's Avatar
Uh Ohh.... nothing is wrong
I wonder if we are all having the EXACT same problem ... we all have 05's..
Old 03-14-2005 | 12:13 PM
TheDanger's Avatar
rims must be rubbing...uhh does it only happen in turning or even in bumps?
Old 03-14-2005 | 02:31 PM
ikhonlord's Avatar
Take a look at your back left rim (If you are looking at your box from the back). The inside of your rim more than likely is rubbing with a bolt back there...I know it happens to me..I believe OneTone Spacers will take care of that problem...
Old 03-14-2005 | 04:14 PM
1loxBchick's Avatar
I'm on 18's and don't hear any rubbing noises
1loxBchick's Avatar
Old 03-14-2005 | 07:06 PM
scion04xb's Avatar
ok well i will check for rubbing i mean it sounds tiny not bad at all so i dunno
Old 03-14-2005 | 07:14 PM
HollyDo's Avatar
I have an '05, I'm on 17's and lowered - no problems or noises here!!
Old 03-14-2005 | 07:32 PM
Lonely_Raven's Avatar
Double check your work, and make sure to have the lug
nuts torqued down the proper amount.
Old 03-14-2005 | 08:09 PM
xlethal's Avatar
i too own a 05 xb standard with 18in wheels, trd lowering, TRD clutch, TRD Shifter, got it all done at the dealer and the sound of metal rubbing IS present.... not only when turning right (though 9 outta 10 times it is) but also when im going straight, its not all the time but it comes and goes.... i went back checked all the work, no metal rubbing anythign from the outside.... thinking possibly inside transmission? flywheel? clutch? sounds like two flat metal plates sliding on eachother... please let me know you guys found out what it is.
Old 03-15-2005 | 01:50 AM
scion04xb's Avatar
yeah thats what mine sounds like i dunno what it is it mite just be the steering pump maybe??? cuz i know when i lowered my neon the steering pump worked harder but i dunno
Old 05-03-2005 | 01:38 AM
xlethal's Avatar
I FOUND OUT WHAT IT IS!!!
so i take my car to Fowler Toyota in Norman Oklahoma on my quest to fix the wire harness that melted in the xB, when they pulled my box around i heard the sound again, so i asked the shop man to check that sound out... its the Heat shield for the brakes... that little plate behind the rotor, all he did was press it back in three spots with a screwdriver and no more sliding sound... what weight off the shoulders! and i thought it was serious :D
Old 05-03-2005 | 01:51 AM
violent_b's Avatar
I think the melted wire harness is more serious then the noise.
Old 05-05-2005 | 01:29 AM
xlethal's Avatar
i got the harness situated, that was my main purpose of going to the dealer. Either way i found out the noise and i think it'll help some people out.
Old 09-02-2005 | 12:55 AM
lppro-xb's Avatar
i have 17" and lowered 2"... no rubbing or grinding sound
Old 09-02-2005 | 07:52 AM
Box916's Avatar
I have a bagged 05 box with 17" rims and I dont rub unless I'm not set high enough when I turn ;)
Old 09-02-2005 | 11:57 AM
BOXCAR's Avatar
I just installed s-tech's on my 04 tuesday and have no problems i'm on stock wheels though.
Quick Reply: ok i lowered my box now...
