one ton garage spacer = _____in' mod!
Old 10-08-2007 | 02:30 AM
BoxOffice's Avatar
Default one ton garage spacer = _____in' mod!
I just thought I'd post to say what a great, easy to do mod these spacers are.
Like most Box owners, the tucked-in rear wheel look has always bugged me, so I popped for a set of the OTG spacers to slip them out toward the edge of the fender a bit, and more readily match the fronts.
At first I thought the $70 price was a bit steep for what you're getting, but not having the equipment to make a set myself, I coughed up the dough and went for it!
I have to say the parts are real quality stuff, very well made (which makes the price much easier to swallow!) and Van is a great guy to work with; good communication, good, honest info beforehand about his product, and he supplies very clear and concise instructions with the parts.
The paperwork lists installation time at 50 minutes, and it took me about 45, including jacking up the car and removing the wheels. Its a VERY easy install. If you can change spark plugs, you can do this.
I almost bought the double set, but decided to go with just one first to see how it would look, and I'm glad I did, because as low as my car is, I don't have any more outward room! The new offset is just about a perfect match to the front, too.
Here's the pics...
Before:
After:
Good stuff!
Old 10-08-2007 | 02:43 AM
burstaneurysm's Avatar
Yea, the OTGs are well worth it.
I love those wheels... borbet?
Old 10-08-2007 | 02:52 AM
987KEITH's Avatar
very true! looks great!
Old 10-08-2007 | 03:05 AM
CREEPINGONCHROME's Avatar
looks good!
Old 10-08-2007 | 03:08 AM
keg79's Avatar
yep, I've loved mine ever since I put em on
Old 10-08-2007 | 08:04 AM
bB2NER's Avatar
Music City Scions
Def a "must do" mod. Too bad the OTGs are only 10mm. I added a set of 1/2 inch ones to make the rears perfectly match the fronts.
Old 10-08-2007 | 09:03 AM
MrMcNuggett's Avatar
I need to get some from mike to put on miyas car.
Old 10-08-2007 | 09:11 AM
bB2NER's Avatar
Music City Scions
Yeah Donnie. You need em real bad. Better hurry before he runs out of them.
Old 10-08-2007 | 11:10 AM
firesquare's Avatar
the best mod i agree also. got em on mine
Old 10-08-2007 | 02:06 PM
swartzautoman's Avatar
yah, ive got em to.
but my OTG style "20mm" spacers were made keoki (SL member) top of the line guy.
Old 10-08-2007 | 05:59 PM
BoxOffice's Avatar
Thanks - yup, "Type S".
Old 10-08-2007 | 06:01 PM
BoxOffice's Avatar
Originally Posted by swartzautoman
yah, ive got em to.
No way I could fit those without some major fender rolling.
I actually rubbed the tires for the very first time last night with just me and my 120 lb. wife aboard!
Old 10-08-2007 | 08:30 PM
my rims are only 7" wide with a 38mm offset.
yours must be wider.
Old 10-08-2007 | 08:40 PM
BoxOffice's Avatar
Nope, same here. BUT, I'm running a fairly big 205/60-15 on the rear.
Look at the views of both our rear tires and you'll see what a difference they make. They look beefy and give me a nice raked stance, but definitely create a fitment shortcoming.
Old 10-08-2007 | 08:46 PM
bB2NER's Avatar
Music City Scions
I had the same rubbing issues at first when I was running 215/45/17s with 1.5" drop and the OTG spacers. Now that I have the right size tires the rubbing is gone.
Old 10-08-2007 | 11:43 PM
andrewdustin's Avatar
dido! OTG the only way to go!
Old 10-09-2007 | 12:25 AM
BoxOffice's Avatar
What size did you go with? I've been playing around with the idea of going with a set of 17s, and was thinking 215/40-17 or even 205/40-17...
Old 10-09-2007 | 12:53 AM
bB2NER's Avatar
Music City Scions
205/40/17 is ideal with the spacers but 215/40 should be fine too. I'm running 215/35/18 with zero rubbing.
Old 10-09-2007 | 02:54 AM
BoxOffice's Avatar
Gotcha. Thanks, Jeff.
Old 10-09-2007 | 10:06 PM
JSosa's Avatar
Very good mod, but i cant run them with my normal tires. I have 16x7 with a 35 offset, but using 205/55 rubber which causes rubbing. But when i go racing and swap for the 15" wheels then those spacers make a huge difference. They actually slightly help the car when cornering hard.
