OTG neg camber plates!!! Finally
#121
Originally Posted by squirrel
Say what you will, but the camber shims were not really made for performance anyway.
It must be a styling thing them.
No way having front camber or rear camber will help increase the tire contact patch while dealing w/ cornering, and the handling characteristics of the car. I always thought better handling came with having a good contact patch from the tires.
I guess I was wrong again. Sorry to give out misinformation.
#122
Whoa, SciFly posted this on the Sticky/FAQ:
When cornering, body roll causes an increase in positive camber,
which pulls up the inside edge of the front outside tire, reducing the effective size of
the tire’s footprint. More static negative camber counters this effect.
For example, if you have 1 degree of static negative camber, and the camber moves
3 degrees due to body roll, you end up with 2 degrees of dynamic positive camber.
If you have 3 degrees of static negative camber, you’ll end up with 0 degrees of
dynamic camber – resulting in a larger tire footprint.
#123
camber plates are not a fad! they are styling trend. Bell bottom jeans are a fad. You guys really nees to look into real JDM magazines like Trend Wagon or Option Wagon. God, How can people be so naive? I hope you're kidding by saying this is a fad. How about this? Buying an exhaust system made for your car is a fad. Tacking on a fart can that points at the ground is a trend. No one buys exhaust systems!!
#124
Guest
Posts: n/a
Where is my head I thought this was a scion forum. I should have clarified that the rear camber plates for the scion are not for performance since we only have 108HP and must not race.
As far as other vehicles, I must say that I have seen camber first hand since precisionmuffler.com sponsors the PDQ motorsports honda race car, and watching that thing take the corners with the camber is really something to experience. :D
#125
Scott
#127
All of the experts can say what they will.
I added camber to make my spirited runs even more spirited. And to help w/ fitting of the 8.5s in the rear helped also.
To each his own, and I have my car set-up for the way I like it to handle.
Oh, and who said it was a "fad"?
I said it was going to be a played out mod because some peeps run mods just because its the newest mod on the market. And some peeps just have to have every single new mod out there.
Styling also falls under a specific theme. Some peeps mix themes and there is not flow.
I notice how some peeps become overnight experts just because a new product is released. I had camber on the front end of both of my Celicas back in 1982/3 when I started running auto-x's.
Just like some experts say beefier front sways are need for FWD cars! Ok...........................................
#129
#130
To each their own. If you want to buy these for style and have the offset to pull it off go for it. If you want to buy these for handling go for it.
I don't have the offset to make it look the way I think it should and don't need the handling so I probably won't be getting a set anytime soon. It is good to see these on the market giving the US more options.
#133
what is HIN
we ain't code breakin' noobs; not all of us.. tho my name ain't Sloan D. Uptake
OK, well I ordered the Van plates. When they arrive this week I'll see how soon I can install them and take pics and maybe make a draw bar test before and after if I can find a suitable spring scale.. Am curious to see how much rolling resistance the toed n.c. makes... for this would make a likely indicator of scrub wear to come. Will do this (if I do the testing) on a level, flat concrete floor, either pushing or pulling on the Scion's towing eye bar. Depends on which kind of spring scale I can rustle up.
#137
I guess the xA in FL doesn't really auto-x then. The pics must have PS'd then if Scions aren't raced. Oh wait, I was watching a tC auto-x a few runs at Monster Park, but I guess its ok since it has more than 108 hp.
Hmm, I know the Honda CVCC I ran a few auto-x's had no where near 108 hp at the crank in 1984, but it was still raced, and in Solo I also!
#138
Originally Posted by sexyscionlover
Lucky Strike Means Fine Tobbaco?
The song.
That made no sense to this topic if thats the acronym I think you meant.
Scott
The song.
Scott
Kudos, Scott, for knowing that the very finest Strikes
were not made by cobras at snake team bowling nights,
but instead were rolled in sleeves; in T shirts as did Elvis
long before you were a man, or could define a pelvis.
#140
What more can we discuss ON topic?
-----ok! got the world's shortest summary of tuner tips in doggy verse:
positive caster: steering master
negative camberornering clamber
vehicle drop: slammed muffler pops
