Post up pics of your air suspension in-trunk tank setups
Wagonistas
Originally Posted by Elijahtc
Omg randode! That is the hotness.
I would do anything to have the $16,000 u want for that B. I want a B so bad!!!! Ha ha
I can't believe somebody hasn't picked up on this steal!!!
Anyone got picts of how you routed your airlines under the car to the front struts(maybe pict of car with front wheel off)? I'm currently planning out my setup and am just not sure where to go with the lines in the front wheel well. Some sick setups here, can't wait to get mine going!
I routed mine down beside the brake lines on drivers side they work well for me there if you are mounting everything inside there is a plug on the underneath of your cargo space that you can remove if you look you will see it
how in the world are you guys able to run compressor's inside with you... I had 2 compressor's outside and they still were very annoying ... I could not imagine having them inside with you..... YIKES...!!!!!
Also anyone have and good picts of their setups mounted under the car? I am NOT excited at all to have a compressor in the car
Mine is a temp setup but the new setup will be similar but the tank and comps will be enclosed in a box with a plexy front to see it and my subs mounted in glass boxes above the setup. This will quiet the comps a great deal.
I went inside because we get crazy bad weather here and the box is my daily driver.
Not the best pics of the airride because i was really taking a couple pics of the wheels, but the only ones I have saved on my computer. Mine is pretty compact, so I can still get the spare out.
Here are some install pics though.
Heare a a couple pics of the stuff mounted:
Here are the valves:
Had to mod up a bracket to celar the senders. The vavles are mounted directly underneath the set up in storage compartment.
All the airlines were ran thru the car (under the sills). The fronts came out thru the brake line holes.
And the digital gauges:
Here are my underbody install pics...
I have s/s tubing, digital gauges, and an 8-valve solenoid manifold awaiting to move everything up and into my trunk when I can stop being lazy. Except the compressor I guess...
Anyone have any noise complaints about the compressor being in the cabin? I know it's loud as shat being underneather the car....I can just hear the complaining from my wife.....
