Problem with Rear Wheel Tow on NEW 06
I went to get an alignment after my Tein coilovers were installed today
I went to the best shop around..and found out my left rear wheel was out of toe bad
.77
anyway, this is not from lowering the car. They are doing a rear wheel shim to correct it, because I will have bad and fast tire wear on the left reae wheel.
I was told this is a factory defect of the rear suspension...
anyone else have problems with the rear wheel toe. this is unsuall I was told..
.77
Funny the right wheel if perfect or within specs. and the left is out a lot.
Should i just leave it or get it corrected...
I was the the if each wheel is off by the oposite number, it's an axle shift problem
Originally Posted by hotbox05
just fix it to give a lil better tire wear. it doesnt hurt.
they are using these 2-piece shims made just for this type of problem..
oh, i paid today for 125.00 for new front camber bolts and the 4 wheel aligment, not including the rear wheel shim they are doing monday..
front camber? your front camber should still be very close to perfect
thats a good price for install of the bolts and such. hopefully they didnt charge u much for the bolts as they only cost 2.99 each
Originally Posted by chucksu
If I recall all the stuff read to me when I bought my xB, stuff like that could be covered under warrenty
Should I push for a complete new suspension...or just do the above
Just get it shimmed. You're likely to be more screwed up if you have the garage monkeys try to tackle something like that plus warranty would never cover a replacement. that's just part of mass-production and why they have warranties anyway.
If they can't or don't do alignments themselves, they may be willing to just reimburse him for the place he's getting it done at. I'd mail in the bill or use someone else's car to drop it off...
Funny cuz my rear right wheel was out of spec when I aligned my car. I left it alone cuz I was told by someone that the toe in the rear actually adjust as you drive. I haven't noticed any uneven tire wear in the rear, (and I canyon race this car like 2 maybe 3 times a week, so I wear tires out fast) the front, now thats a different story.
Was it toe or camber out
kleecker
9
08-02-2022 05:00 AM
Slopoke21m
54
04-23-2007 12:25 AM
bBOXD
28
12-07-2003 07:08 PM
