Rough Ride, Smoother ideas?
Old 09-25-2008 | 04:16 AM
emeraldstereo's Avatar
Default Rough Ride, Smoother ideas?
Hey all.......
I have a 2006 XA. I have 17" rims, TRD Shocks kit and hotchkis sway bars all installed and the car rides like crap. I feel every crack and rock I run over. I hit a pot hole and the car goes insane...steering wheel has its own mind! I can't drive without both my hands on the wheel because even a hump in the road causes the car to turn left/right. I'm thinking it was a mistake to do this......Any suggestions? Maybe a different shock kit? Get rid of sway bars?
Any help would be great!!!!!
Chris.
Old 09-25-2008 | 04:41 AM
burstaneurysm's Avatar
What springs are you on?
Old 09-25-2008 | 05:01 AM
I don't have any aftermarket springs. Is that my problem? If so, which springs should I get? Any help most appreciated?
Old 09-26-2008 | 12:29 PM
uninc's Avatar
Smaller wheels with a bit more tire on them would help alot, otherwise try to get some monroe shocks. Alot of the xb guys are doing that with good results.
Old 09-26-2008 | 02:09 PM
sciondude410's Avatar
Stock Suspension and tires. Any modifications to your suspension will make it stiffer and if you do bigger wheels and smaller tires then its just a trade off that you have more "feel" of the road. I have been running 18's with 35 series tires and tein s-techs. I felt every bump before I even hit it!
I just changed to 15x8s with 195/55/15's and they have helped alot with the feeling of bumps and cracks.
Mike
Old 09-26-2008 | 03:12 PM
17s aren't really that bad for the ride.
The TRD shocks are stiffer than the stock ones.
Old 09-26-2008 | 04:11 PM
DPIQ's Avatar
Recheck your alignment and make sure your wheel offset is close to stock since you didn't lower the car. Both can cause twitchiness in the steering.
Old 09-26-2008 | 10:01 PM
thanks for all your comments. I had an alignment and had it checked twice. I really believe it has to do with the rims. I just recently had them installed, so I don't wanna get new ones. I'll probably wait a year, get 15" and try different shocks and springs. Which are the best springs?
Old 10-21-2008 | 04:18 AM
Eddubi's Avatar
Light car...stiff shocks..low tires....hard ride...Try going with cheap shocks...the ones that have no little or no rebound. (not gas filled)
Old 10-21-2008 | 08:04 PM
silverevo05's Avatar
right now I have trd springs monroe shocks trd sway and es endlink bushings.
the monroes might help a bit, but what seems to really help the steering not be so twitchy was the endlink bushings (20 min install)
I compromised on the wheels. I wanted 17s but the ride I feared was going to be too stiff so I went with 16's.
Try to remove the sway, that transfers bump from one side to the other
Old 10-23-2008 | 04:56 AM
bB2NER's Avatar
Music City Scions
I agree with Ian. Swap out the TRDs (re sell them on here) with some Monroes all around and get some mild springs like Tein H techs. Ride will be smooth man.
BTW, what size tires ya got on those 17's? If you are running 205/40's bump them up to 215/40s. It will give a much better ride.
Icanmanifest
04-09-2015 02:10 AM
killahXB2
03-27-2015 10:45 AM
brownSys
02-27-2015 04:20 PM
cid_mcdp
01-05-2015 02:45 PM
KKWL
12-04-2014 07:12 PM
Quick Reply: Rough Ride, Smoother ideas?
