Show me your bagged xB
#101
Brandon you have the FBI brackets... Simple Solution, Cut the cup on the top plate (the one that bolts to the car) in half and the one that sits on the lower spring perch cut an inch off of that one...
#104
is it possible to just have the front air bagged? cuz my new front bumper be scraping and be denting everytime i go on and off ramps streets. i just want it for use of of lifting it up everytime i come upon it and nothing else. my car is already lowered two inch. just wondering if i can have it Air Ride Bagged only on the front?
#106
one more question. how strong can the rear hold if i was to put air ride bagged on the rear also with a bit heavy loads. because im a DJ and every weekend i always be having some heavy loads in the back. (2 Speakers and turntables) my lowered rear 1.6 inch spring (becomes 2 inch when the the DJ equipments are inside) can handle the weight. just wondering if the air ride baaged would handle it and last iternity.
#113
Low down you are def. down low...thats cool taking the front off, gives you a good "up skirt" view of thats goin on, too bad your side fenders aren't off too lol, how much work did you have to do?
#114
too much...all the body work still needs done, the other side skirt needs to be put on, and there is no interior, and everything will be fiberglassed formt he dash to hatch, it all needs done. somehow the MAF sensor broke on saturday so i had to fix that too
#119
still have a long way to go, need to redo the exhaust and get rid of the axle back, Maybe do a 4-link or something diff, not sure yet.
need to notch the frame up front more even though it is sitting on the ground now.
