Squeak- Squeak-
Old 03-31-2004 | 03:55 PM
proto_k7's Avatar
Default Squeak- Squeak-
Does anybbody know how to eliminate the squeaks on the rear springs for an XB? I am running JIC's......
Old 03-31-2004 | 04:04 PM
ComaJoe's Avatar
Tri-Flow! =D
http://www.tri-flowindustrial.com/
can be found at any (mountain) bike shop or on ebay of course.
I have VERY squeeky polyurethane bushings in my upper control arms for my truck and I tried different methods for months to get rid of it. then I tried some of this stuff and I haven't had a problem since. it's heaven-sent, I swear! =D
-ComaJoe
Old 03-31-2004 | 04:11 PM
proto_k7's Avatar
I am familiar with TRI-flow, you must be a rider....... My concern is that metal to metal contact, tri-flow will only work for so long and it will produce a dirt and grime build up around the adjusting nuts on my coilover. Lubricating was one of my first options to mind but I think it needs an actual sound deadning pad or something....
You are on the right track, thank you for your input comajoe!!
Old 03-31-2004 | 04:20 PM
proto_k7's Avatar
https://www.scionlife.com/forums/vie...t=rear+springs
found sumthin'
Old 03-31-2004 | 04:33 PM
boxhead's Avatar
I wanted to get a warranty on my ____e so I bought the TRD springs to go with the 18" TRD Rims. Don't hate...congratulate!!
Boxhead :twisted:
Old 03-31-2004 | 04:36 PM
proto_k7's Avatar
I had TRD's, those rode nice but I had to upgrade to an aftermarket for the drop and dampening....
Old 03-31-2004 | 04:40 PM
Infiz's Avatar
Are you sure the squeaking is comming from your springs? A lot of suspension squeaks sound like that, but they're actually the control arm bushings. Make sure you lube in the right place!
Old 03-31-2004 | 04:52 PM
proto_k7's Avatar
this is like after the JIC's were installed. They never squeaked before. I would have to bet it that its the springs. I am going to get off my ___ here and go look at it, I need to rotate my tires anyway..
I will let you fella's know in a few.....
Old 03-31-2004 | 04:55 PM
projxB's Avatar
Originally Posted by ComaJoe
Tri-Flow! =D
-ComaJoe
hahaha that sounds like a comercial. they should pay you for that one.
Old 03-31-2004 | 05:23 PM
rotarycolt's Avatar
Boxhead :twisted:
So what you're saying... is... "Don't hate me because I have the same wheels as everyone else, and the same 1" drop everyone else does"
Old 03-31-2004 | 05:39 PM
ComaJoe's Avatar
Tri-Flow! =D
-ComaJoe
I absolutely agree! SHOW ME DA MONEY!
-ComaJoe
Old 03-31-2004 | 06:01 PM
Scott17's Avatar
StyleWagons
Permatex anti-seize works well on bushings and springs.~~~~~~~~scott
Old 03-31-2004 | 06:11 PM
BigOrangeXb's Avatar
Are you absolutley sure it's the springs causing the noise? For the past 4 days mine would squeak in the rear over uneven road or when turning. It was driving me crazy cuz it didn't do that right after I installed my Tanabe's. Found out it was the rear seats weren't latched all the way! The striker and latch would rub since they were a little loose and make a loud squeaking sound.
Old 03-31-2004 | 06:47 PM
Tamago's Avatar
cut a small rubber donut from an inner tube.. inner tubes from a wheelbarrow would work great!
Old 04-01-2004 | 09:39 PM
boxhead's Avatar
Jdaniel ....If you dont have nuttin nice to say, keep it to your self.....hater!
another puppy lookin to get walked.
I haven't seen one up here in NE yet with 18" TRD Rims .
Like I said b-4 ...Dont hate congratulate!
The Box :twisted: :twisted: :twisted:
Old 04-02-2004 | 01:40 AM
rotarycolt's Avatar
You're the one thats hatin, by supporting overpriced dealer mods.
Puppy, eh? From the looks of it, you're the one who can't speak anything but a mix of gangster jibberish and AOL language...
I wasn't hating, you just stuck your 2 cents in every post you could, talking up your factory mods like no one else has them... I just think it's obsurd to purchase factory wheels for so much money... You can get a set of high quality aftermarkets for cheaper than that.
Old 04-02-2004 | 02:03 AM
Scott17's Avatar
StyleWagons
Factory parts tend to be the highest quality in my experience. The TRD wheels are RacingHart wheels and for 18s they are some of the strongest I have seen. Sure they are not as inexpensive as some others but what if you have the money? Different strokes for different folks. That is what makes cars interesting. Enjoy~~~~~~~~~~~~~~~scott
Old 04-02-2004 | 09:00 AM
Guest
Guest
Posts: n/a
BACK ON THE SUBJECT HERE!!!
https://www.scionlife.com/forums/viewtopic.php?t=7691&highlight=rear+springs
found sumthin'
Did you ever find anything usefull here? Was the squeaking from the springs themselves or is it the rubber bushings? I need to know because I just installed some teins and the customer has not had any problems at all. In fact you should PM him to see what he says. His screen name is " boxlax " He had the precisionmuffler.com axle back installed and the tiens at the same time and he loved them both.
AllianceAutoSports
07-24-2008 07:25 PM
Quick Reply: Squeak- Squeak-
