Stock struts with aftermarket springs
Re: Stock struts with aftermarket springs
Originally Posted by StevisXb
At what point should replace the stock struts? For example, the Eibach Pro-kit lowers 1.5/1.6", will this work with the stock struts?
its also cheaper to put in better struts and shocks at the same time as springs, since you have to take them off to put the springs in. and then if you ever sell car you have a set of factory parts to put back on
Originally Posted by BUniqueXB
I've got tanabe df210's on my box and my stock shocks/struts are all but destroyed, so i'll agree that its a good idea to change em out whenever you have the car dropped
yeah this is all true but lowerd / shorter shocks are around 200 a corner. not cheap. and they are normally only meant for say a 1.5 inch drop. it's unfortunate. get ahold of ground control . they build shorter shocks for any and all applications.
FYI, we always recommend replacing your O.E. "Damper" anytime a vehicle is lowered. Not only are most O.E. dampers are not up to the task once a vehicle has been lowered, if they fail shortly after you install your lowering springs, you will be faced with double labor and alignment cost!. For more information and to review the products we have available for your vehicle please visit our site at:
http://www.tirerack.com/a.jsp?a=DJ1&...sion/index.jsp
Scionxa180
07-11-2015 10:50 PM
darkshadowofxdeath
12-03-2014 06:59 PM
ScionVan
11
12-02-2003 09:37 PM
scionaraxb
10-14-2003 03:20 PM
