tC sway bar installed on an xB!!!
Old 11-10-2004 | 02:02 AM
Guest
Guest
Posts: n/a
Default tC sway bar installed on an xB!!!
So I was once again bored at the scion central and decided to take it appon myself to install a tC stock swaybar onto my xB. With the help of scionjohn and the blessing of tChillen for his old swaybar. I went to work, scion john helped me do the drilling and alignment, with evilsciondude supervising. After wards I had the sway bar bolted down on the rear arm bar and than fabricated some connectors to the rear shocks, just like the white line rear sway bar set-up. The aftermath, no roll what soever, my xB is ready for the track and around corners is incredible. The tC rear stock sway bar is so much thicker than the hotchkis I was blown away at the difference.
The tC swaybar and the hotchkis rear sway bar. You can see the difference.
So if you got a buddy with a tC, and they installed the trd. Ask them for their old tC swaybar and have a shop install yours today!! :D
Old 11-10-2004 | 02:10 AM
unlmtdndeavor's Avatar
nicely done gabe...ill make sure to get my hands on one if i can find it
Old 11-10-2004 | 02:27 AM
Guest
Guest
Posts: n/a
Sup man!! Haven't seen you in a while!! If you need help installing let me know, I got a rack open for you.
Old 11-10-2004 | 02:28 AM
Munch's Avatar
Very nice
Old 11-10-2004 | 02:32 AM
Guest
Guest
Posts: n/a
thanks munch, just another mod for everyone else to enjoy.
Old 11-10-2004 | 02:50 AM
Kaeon's Avatar
You crazy mexican!!!! Nice man real nice!
Old 11-10-2004 | 02:54 AM
Guest
Guest
Posts: n/a
LOL Dude, I am on the ground for real though!!! You know I have to be different and try new things, or else I am just a regular mexican.
Old 11-10-2004 | 03:01 AM
squirrel's Avatar
Default Re: tC sway bar installed on an xB!!!
Originally Posted by Stylis
Hmm, I'm not so sure about the link that's fab'd on there. And the way the bar kinks downward looks like there may be some clearance issues...........................sorry Gabe, not for me.
Old 11-10-2004 | 03:05 AM
2fixA's Avatar
ooh, quick reply... got to give you props for trying man, that's just nuts... need to check out that setup in person tomorrow night
Old 11-10-2004 | 04:44 AM
Dewmerz's Avatar
How hard would it be to extend the bar up to the mount point with the same size round stock or use a strong enough tubing to sleeve over the bar and flattened on one end for the bolt? The flat stock bothers me for some reason. It's just me though.
I think it is a creative idea.
Old 11-10-2004 | 04:47 AM
hotbox05's Avatar
yeah looks cool i bet within a week or so gabe will fab up a better way.
Old 11-10-2004 | 05:01 AM
JDMxB's Avatar
I really don't know if that's even safe...
Good luck, hope everything goes well.
Old 11-10-2004 | 02:54 PM
EVILDAVE's Avatar
Who the hell is this guy?? :twisted:
Whats up Edwin?
Old 11-10-2004 | 03:43 PM
squirrel's Avatar
Gabe, I would seriously, seriously, seriously, rethink this "link" you have connecting the swar bar to the shock mount.
Either, try and shape the bar to mount to the shock mount, or find a Hiem joint that would work. Or a piece of angle iron or something. That flat piece appears to have no structural rigidty, and under repeated heavy loading, will fail, and who knows what damage will occur.
Old 11-10-2004 | 03:46 PM
squirrel's Avatar
Also, some nylock nuts here wouldn't be a bad idea.
Old 11-10-2004 | 04:03 PM
ScionSniper's Avatar
squrrel, it does look a little if'y, but I worked it out with Gabe. We had to go down with the bar because of clearence and we still have plenty of ground clearence. As for the connecting link. Its pretty sturdy. Gabed used a 1/4 in. piece of steel to fab that. I think it will hold pertty well.
Old 11-10-2004 | 04:05 PM
Guest
Guest
Posts: n/a
have had it on for a week already and I drive hard. Not one problem. The links are working great. I tried to raise the swaybar up just a little bit but than it was hitting the spring holder. The swaybar also doesn't pass the inner wheel so i am not worried, I have already driven over some speed bumps at an angle to see if there are any problems; end result a perfect performing swaybar. The endlinks I made have to be heated with a torch to bend them, so I am not worried about them failing.
[qoute="squirrel"]Also, some nylock nuts here wouldn't be a bad idea.
[/qoute] The bolts are under pressure and I rechecked them yesterday to see if they are coming loose from last week, not one loose nut. Although that is not a bad idea.
Old 11-10-2004 | 04:11 PM
squirrel's Avatar
Well, ok. As long as you keep checking it periodically. Remind me not to drive behind you.
Old 11-10-2004 | 04:20 PM
Guest
Guest
Posts: n/a
Hey squirrel, drive behind me!
Old 11-10-2004 | 04:23 PM
squirrel's Avatar
That's ok. I don't need to replace yet another windshield.
Quick Reply: tC sway bar installed on an xB!!!
