Tein H techs with stock shocks
I am going to buy some Tein H Techs because I want to improve handling and get rid of the huge xA wheel gap. Will it be totally fine to leave the stock shocks/struts in? The drop is very subtle... just approx. 1 inch. Thanks.
you should also look into hub shims like OTG. I noticed the fender gap after I lowered my box on h-techs. about the struts most people I know run the stock struts and shocks w/no problems.
I have had H-techs on the box for a while now. I didn't want a drastic drop and I was into the idea of a so called "softer" ride. In my opinion the ride didn't really soften up, but I did notice more body roll. I am not so sure these springs are really conducive to "better handling". Its not a huge deal for me, but it depends on your definition of what a better ride is. At this point I would like to have better conering ability since the "softer ride" thing didn't work out, but I am not sure what spring will be comparable as far as lowering specs. I know the TRD's are about the same and are stiffer, but I have heard people complaining about how the rear sits lower then the front....I am all set with that.
Kind got off on a tangent there.....anyway, I have had the springs on for 32000 with the stock shocks & struts w/no problems.
The H-techs are more of luxury springs and just give the car a nice drop. I dont think their made for "handling" purposes especially with stock shocks. If you want more of a handling kinda suspension i would suggest you would get some Eibachs w/ some aftermarket suspension.
hmmm, I've noticed alot of body roll has been diminished, and handling has been upgraded. I can go around corners about 5-10 mph more then with stock springs.
^ It's probably because the Teins are progressive rate vs. the linear (sucky) OEM springs.
In response to the origional post, I'd get the Monroe SensaTrac shocks/struts for when you do the springs. If you do a search on here people are saying the work great together, and they are also very affordable.
yardleyTC
03-06-2015 10:03 PM
