Triple Rear Sway Bar Setup (pic)
This way- I can run 1, 2, or 3 bars on the rear, depending on the situation.
1 bar = understeer (just the OEM bar)
2 bars = balanced (I also have the Hotchkis front bar)
3 bars = oversteer
-Pete
3 bars = oversteer
-Pete
That car is CLEAN!!! Do you even drive it?? Looks like that car has 100 miles on it . What coilovers are those they looks nice?? BTW, is that the progress rear sway bar?? I never thought of doubling it up, but it might just work.
Yeah, how about some info to go with the pic, please!
Cough up sway bar mfrs and diameter, and a little something about those shocks!
Is that an adjustable height rear spring perch, too? I haven't seen that before.
(*And "OEM" rear sway? My '06 didn't have one from the factory...)
Originally Posted by autopainter13
what kind of rear shock is that?
-Pete
Originally Posted by nerdsports
What kind of sway bars are those??
The rear bar looked like I could stack another on it, so I gave it a try. So far, it works well (with some minor mods). The bars are 12mm each.
-Pete
...and i'd love to know how you keep your undercarriage clean!
If you want it to look clean, you have to clean it. I wipe it down with moist cotton rags.
It's also an '06, so it's still pretty new.
-Pete
It's located in the suspension cross beam.
I think the adjustable height spring perch is something new from JIC Magic. I didn't custom order it, I think it's the normal version for the xB. (I have an xA). My old FLT-A2 rear shocks didn't have it.
-Pete
Hmm. I'm just wondering why you couldnt go with a Whiteline or TRD rear sway bar that is about 22-24mm alone. Then perhaps you could add the Hotchkis bar (if you wanted).
And all COILOVER kits come with adjustable spring perches in the rear. How else would a coilover system work?? =P
You're right, the JIC kit always came with the adjustable spring perches. The new part is the adjustable height shocks.
-Pete
