Triple Rear Sway Bar Setup (pic)
do you have a picture of the back spring when its under a load?
when my xb is on the ground the coil is completely compressed and i wanted to know if thats normal.
im running a stock shock right now and im wondering if that might have something to do with it
Originally Posted by SkyonXa
Originally Posted by BoxOffice
(*And "OEM" rear sway? My '06 didn't have one from the factory...)
After seeing this post, I'm thinking about adding a Hotchkis to the mix, too. Even with the two bars I've got, it doesn't feel flat enough out back. It looks like it would fit without getting in the way of the Progressive.
-Pete
-Pete
-Pete
Originally Posted by hotweelz4me
yeah adjust it down. The first pic is adjusted all the way down and the second is oposite all the way up
This is how it sits with them adjusted all the way up.
-Pete
wow... saggy springs then. that sucks, i didnt think JIC products would ever sag like that
I contacted them about an hour ago and hopefully I will be able to get a replacement spring that will work.
Using two rear bars is a great idea on our cars. I know a guy who used to race a VW Rabbit in some pretty serious SSCA stuff, and he ran it with NO front bar and two stock rear bars he custom mounted. He kicked ___ in the class he was in, even ran it in the One Lap of America several times.
did you have to get longer bolts to get thru both bars
if yes where did you get them and what should i look for
Got them at Orchard Supply Hardware. Most any hardware store should have them.
-Pete
i see your adjustability side of it, but i too would have just gone with a single bar... progresive being 22mm and whiteline *apparently* being 24mm when the one i found is a 22mm.
having the two bars though does give some originality to it.
-Pete
I was researching rear springs and came accross this thread. I have the D2 Coilovers and the rear spring is too soft for me. I have the rear shock adjusted long and have a little preload on the shock. But i need some higher spring rated rears.
Does any body know how to obtain a stronger rear spring.
Here is a picture of mine.
It is adjusted all the way up on the perch.
-Pete
If anything the stock shock is taller and ofcourse not as stiff as an aftermarket shock
