What struts/shocks are ideal for S-Tech Springs on xA?
Okay, at first I wanted to put the S-Tech with the stock struts/shocks on for now, since the car is still new. Then upon reading more I read people are having struts/shocks issue after 10-15k, so I am thinking what struts are good then for the S-Tech?
I have read people using TRD struts/shocks, and I wonder is that the only ideal solution? Surely many still use the stock ones and are happy, so I am a bit confused...besides, the TRD struts/shocks can get quite expensive.
Thanks all!
Thanks all!
You can find the TRD shocks/struts for about $300. Yeah, that might be a little steep for some people, but if you want more, Tokico also makes 15-way adjustable dampers for like $550. It depends on what you're looking for.
You could always drop them on the stock struts and then switch to the TRD struts when/if they blow out... or you could do it now. Either way, they will both give you that drop.
Well my friend is doing that for me free of charge, but I figured it's easier to do both at the same time, especially for the front, so to save him some troubles. At first I have read people saying stock struts/shocks work fine, and I was thinking how long would they last? Upon reading more about this topic, I found 15k max and that's not a whole lot. That's why I am thinking about doing both at the same time. Of course, getting just the springs vs the whole set yield a bigger difference in cost; that's the decision I guess. Thanks!
I don't think my wife cares too much about harsh ride, after being in both of my cars. I am just concern of reliability of using stock struts/shocks with S-Tech or if aftermarket struts/shocks are needed to match the stiffer springs. I think the TRD is expensive already, and adjustability isn't really a big concern since the xA is not really a sport car. I just want her to handle better (safer), looks better (drop) and cuter (already is).
Thanks!
Thanks!
Naughtygoose
07-06-2015 09:59 PM
