Whats better, coilovers or bags...
How bout you guys try air ride on a car/truck with a 454 in it. and tell me how the torque doesn't snap anything.
Honestly guys, a broken line or blown bag, won't make you lose control of your car and die. You know what would happen? Whatever side it was on, it would just leak down and thats about it. No worse than a flat tire.
Hotbox05. i don't mean you are the ignorant one.
All in all, air isn't as bad or unsafe as you all think. so instead of some fighting game, i think this would be better as a opened and closed discussion since its turning into a brawl.
i do believe that bags are pretty much for show..but i dont think much people have intentions of auto-X with their xB. I used to have coilovers on my civic just b/c lowering springs arent adjustable..when i bagged my s10 i was introduced to bags and im glad to have it for the past 3 yrs. yes bags do have cons but IMO, i'd rather have it than coilovers b/c you dont have to get under ur car or anythign of that sort to adjust your ride height (im only talking about ride height now, not dampening)
Originally Posted by TXboxdriver
riddle me this one RTon
how can u adjust the stiffness of a bagged suspension without changing the ride height
pressure = lift or drop
now there are some specialty kits out there for WRX's and other sports cars
not to mention the OEM air suspensions
but these are in no way feasable on our vehicles
the rally guys have implemented a "stiffen-on-the-fly" suspension system
it is controlled by a computer
and adjusts dampening by magnetizing a iron based fluid to stiffen/soften the ride
it does this thousands of times per second
requires very accurate ride height sensors
and costs more than 30 xB's to have custom made for the car
my dad has the praxis air ride suspension for his wrx. it is meant for SCCA. gradual, adjustable height, and it adjusts to turning. now that is decent. but im glad i have a bunch of people taht stand behind me on coilovers.
http://www.tirerack.com/suspension/s...BA1&perfCode=P
that is what my dad has on his car
Originally Posted by hotbox05
manufacturing defect or not a blown bag or line at 100mph will kill....
and they arent outlawed because you could adjust inside the car. the system could be setup before the race and have no inside adjustment. it's about safety , weight , and moving parts , lines , and being a much more complicated system.
And as far as safety is concerned, pneumatic suspensions are among the safest out there. There is nothing inherently unsafe about pneumatic suspension. It is the improper design and implementation of pneumatic suspension that is unsafe. Just as improper design and implementation of a traditional steel suspension is unsafe.
then read about how often bags or lines blow/break/pop. whether it's defect or instal.. springs hardly even break unless you cut them , heat them , or are grossly overloading them......
i never said air suspensions in general are unsafe but the possibility of a blown bag or line at speed has convinced me not to put air on any vehicle i will be traveling more than 70mph with.
i will have air when i get my old c10 but until then nope.
i still drive fast and hard in a slow **** xB or not.
The claims made on this site would be like reading a story about someone with no training who steals a plane and crashes it. Then turning around and saying planes aren't safe for travel because that one crashed. Air bags and other forms of pneumatic suspension are as reliable and trustworthy as any other system out there. As long as the systems are engineered, designed, and installed properly. Not to mention they offer a greater degree of adjustability and tune-ability than just about any other system out there.
when have you ever seen a steel spring turn into a rod in someones neck? never,,,,
what about air lift struts , and rear bags , and whether it's installed right or not. bags can mess up...
let alone if theres road debris that goes under yer car then snag a bag bam. cant snag a coilover spring.....
you install a coilover setup wrong you wont go down in one corner at speed. worst case is your a little bit lowere on one side. or if you're a complete retard at installs you have a blown shock or a nut comes loose. but that's gross install negligence.
and every car or vehicle i've driven or ridden in that was on air was uncomfortable and a bit sketchy..... not saying all are. but every one ive been in was.
whooooooooo cares.....coilovers nice for racing ..bags great for show...buy one or the other what ever your need., and as it looks a majority of us cant afford eather.so stop fighting which one is better.
Anything bad enough to take out an air spring will most certainly do damage regardless of what components you are using. Are the rubber compounds more susceptible to damage than a piece of wound steel rod? Most certainly. Can they take the abuse expected in every day use on America's highways? Absolutely.
And remember... there is a key word in every statement that I have made regarding pneumatic suspension. That word is "system." A pneumatic suspension system is more than the some of its parts. All of the components chosen for a system must work together. From correct air spring selection (load rating) to correct shock or strut selection (dampening). And even then it must be properly tuned. Things like mounting locations, shock angles, alignment pressure/height all have to be considered. A good pneumatic suspension is a lot more than throwing a couple balloons under your car and filling them up with a helium tank.
We are all Scion owners, and I hope that something as small as a disagreement over which suspension one person prefers wouldn't cause a divide.
Besides, what looks like fighting to some, can be informative to others.
as far as big rigs they sit alot higher than most bagged cars do.... and that's a fact. we are both reaching for the sky. lol....
to you anyone who isnt a pro installing an air bag system shouldnt be doing it. yet lets say someone who is really car savvy is installing a pneumatic system. lets say he unsuspectingly uses an inferior bracket to hold a line. the line comes loose and drags the ground. bam loss of air.....and yes i know you can install extra valves so this doesnt happen but not very many people do it. let alone the cost and extra work that is required...
or lets say someone loves to slam the schnit out of their bags and weakens the bag... so lets say they are driving hit one bag up and then it pops.. lets say they were going 40 or so. safe enough but still sketchy...
lets say the same weakened bag is at constant pressure at ride height...... going down a bumpy highway at say 90 mph. hit a huge bump and the pressure exerted onto / into the bag.... causes it to pop. lets say that it happened on a slow gradual curve at 90. blammo your hitting the wall . or if theres no wall your unlucky **** will hit another vehicle head on. and no that wasnt from improper install or faulty equipment...... just someone who thought they were using their bags properly/correctly. yet they weakened their system at an accelerated pace.
it can be safe but with alot more variables coming into play when using a pneumatic system i'll take my chances with a metal formerly coil spring through my neck.
basically what braddah hotbox05 is trying to say is, if you arent car savvy. STAY AWAY from them and let the pros work on them. see me, i dont trust anyone else working on a car but ME lol
i'm as close to a pro as you can get. almost all of the knowledge just no papers.
i'm just saying with air there is always a risk of a bag or a line blowing. with coilovers there's really no risk like that.
this is true. i'm just stating it's a higher risk. not liek death wish but a higher rick nonetheless. and the less experience you have with cars in general the higher the risk. let alone running air without knowing how to.
but system for system a pneumatic systems has a much larger chance of something going wrong than a coilover setup. whether it's from install , manufacturing , materials used. or hell just wear and tear.
as well as the maintanence as far as draining your tank , using a water seperator , checking valves for leaks , making sure you use dump filter as too keep sand and dirt and debris out of your valves so they dont leak. just alot more stuff going on. and each little component of an air system can cause a leak or a problem.
alltho i dislike air it can be great. but let me say this.....
if you even think you may have a hard time installing. and dont have a pro to go to and learn/help do not do it.
whether air lift is engineered well or not it's widely sold and most peeps who arent in tune may buy em and bam....
Unless you are exceeding the maximum constant design pressure, the chances of actually "popping" a bag because of a pressure spike is almost zero.
It is all personal choice and personal preference. It is just sad to see that so many here have been soured to the thought of pneumatic suspension because of bad installs or poorly designed products. Pneumatic suspension can be just as reliable, and offers the greatest degree of tune-ability available.
The fact remains, it boils down to preference and ability. Choose what you like, and have the ability, or money to have installed properly.
Darrenohooligan
09-26-2015 07:21 AM
rmz489
09-16-2015 08:19 PM
