Where do i get Camber Caster plates?
Im going to Bag my car,... and all the ones that i see with bags, the wheels are straight. Im guessing thats due the Camber plates. If thats so,... where can i get some. If thats not why, i would like to know why.
Camber plates are not necessary to reduce negative camber on the xB. The suspension design allows it to be severely dropped and still be easily aligned within spec.
If you are looking to add camber because of personal preference I would start looking for some Cusco camber plates. Otherwise count your blessings that the xB has the front suspension design that it does.
Correct. The car will not require camber plates to keep the front or rear from being severly out of spec. However, the Easystreet kit made my car have positive camber which was corrected by removing part of the material on the bracket that connects the strut bag to the knuckle/hub assembly.
Darrenohooligan
09-26-2015 07:21 AM
domincnTC
08-04-2015 01:47 PM
Subaru86
07-31-2015 04:33 AM
