Whiteline Swaybar on xB
Old 07-16-2006, 03:19 AM
  #41
evosky's Avatar
how about compared with a TRD rear sway bar ? i would assume that TRD would know pretty well how to do a correct setup ... but then that's still assuming >_<
evosky is offline
Old 07-16-2006, 04:10 AM
  #42
hayalex6's Avatar
TRD sway bar = Progress sway bar. Other than the TRD being red, there are no differences.
Here are pics of my whiteline sway bar installed.
hayalex6 is offline
Old 07-16-2006, 05:45 AM
  #43
Music City Scions
bB2NER's Avatar
Great pics hayalex6!!! Oh and Happy B'Day too!
Me so happy cause my Whiteline bar gets here on Monday. Plus I got the last one the factory had in stock. Lucky me. Ha Ha
bB2NER is offline
Old 07-16-2006, 01:34 PM
  #44
Bsbox's Avatar
How much does the Whiteline weigh?
Nice pics, thanks
Bsbox is offline
Old 07-16-2006, 05:59 PM
  #45
BrianxB's Avatar
Weight of the bar? Probably 2lbs? I wouldnt worry about the weight compared to how well it improves handling.
BrianxB is offline
Old 07-16-2006, 07:46 PM
  #46
Music City Scions
bB2NER's Avatar
UPS said it's 17 lbs on my invoice.
bB2NER is offline
Old 07-16-2006, 09:36 PM
  #47
evosky's Avatar
haha 17 pounds. that's most likely all the packaging and crap. looks like a quality piece...
maybe i'll get it next summer, spent too much already this summer >_<
evosky is offline
Old 07-17-2006, 06:39 PM
  #48
hayalex6's Avatar
no. the packaging weighs 5lbs at MOST.
The bar is solid, and heavy. I dropped it on my toe, and it hurt like a muthafuka.
hayalex6 is offline
Old 07-17-2006, 07:38 PM
  #49
DevilsSi1481's Avatar
im curious but would the whiteline sway bar work together with the progress? because it looks like they would both be able to fit on the car at the same time.
DevilsSi1481 is offline
Old 07-17-2006, 07:41 PM
  #50
hayalex6's Avatar
I was wondering the same thing when I put my Whiteline on.
I'll see if I can borrow my friends progress and fit it.
hayalex6 is offline
Old 07-17-2006, 07:44 PM
  #51
yeah cause ive installed a progress sway bar twice so i know it goes under that bar that the whiteline connects to and offhand from visuals it looks like it will so im also wondering what kinda affects that would have.
Old 07-17-2006, 07:50 PM
  #52
hayalex6's Avatar
very very stiff rear end.
hayalex6 is offline
Old 07-17-2006, 07:54 PM
  #53
Oversteer in a front wheel drive car is fun! haha but yeah let me know if u wind up trying that setup out.
Old 07-17-2006, 10:26 PM
  #54
Music City Scions
bB2NER's Avatar
just got my whiteline bar. Its weight was 18 lbs. and the bar is really heavy .. came in a double box for strength.
bB2NER is offline
Old 07-17-2006, 10:30 PM
  #55
Music City Scions
bB2NER's Avatar
Magic man 808 already tried to fit both bars and it doesnt work .. the mounting brackets for the whiteline interfere with where the progress bar runs.
bB2NER is offline
Old 07-20-2006, 03:12 AM
  #56
Jhhnn's Avatar
Both designs accomplish the same purpose, to stiffen the torsion beam, transferring force from one side of the car to the other. Neither one actually attaches to the unibody, at all.
While the Whiteline may offer some slight improvement over the Progress in competition scenarios, that remains unproven, merely asserted by some as true. If Motor Trend mounted one bar and then the other on the same car and pronounced a winner, I'd tend to believe them...
The Whiteline has its own disadvantages, which are quite real- it's obviously more difficult to install, and it has bushings that will ultimately wear out... Not to mention nearly impossible to obtain...
As for using both bars together, it seems to me that at some point the whole idea of semi-independent rear suspension would be negated by too much stiffness in the torsion beam, causing it to act more like a straight axle...
Jhhnn is offline
Old 07-20-2006, 03:12 PM
  #57
brambling's Avatar
That's true plus the torsion beam is already stiffened once with the inner factory swaybar. As it was originally designed for the Echo it had no inner swaybar.
Although the factory swaybar doesn't seem to attach to the end of the torsion beam like the Whiteline, Progress/TRD and Hotchkiss, just in the straight part across.
For those thinking you would be "doubling up" with a Whiteline + Progress, you really would be tripling up.
brambling is offline
Old 07-21-2006, 08:19 AM
  #58
bBoxed_In's Avatar
if you're planning to double or triple up on sway bars you might as well consider a roll cage already. a well designed cage will definitely stiffen things up.
now honestly... who's willing to go that far w/ their xB/xA?? (sorry, show cars don't count )
bBoxed_In is offline
Old 07-22-2006, 05:49 AM
  #59
Music City Scions
bB2NER's Avatar
It uses polyurethane bushings when properly lubed should last for a LONG time because there isn't much movement like there would be if the bar was mounted to the frame then the axle. It sits stationary most of the time and moves with the axle.
bB2NER is offline
Old 07-23-2006, 03:23 AM
  #60
nnnickkk's Avatar
so whiteline>progress?
nnnickkk is offline
Quick Reply: Whiteline Swaybar on xB
