Whiteline Swaybar on xB
Old 09-11-2006, 10:02 PM
  #61
goyogi's Avatar
Default Missing instructions
I got my Whiteline rear swaybar today. Unfortunately there were no instructions. Does anyone have the instructions that they could fax to me? I've send whiteline an email as well but I'd rather have the instructions sooner so I can install it this evening. By the time Australia is working it's too dark to install.
I also weighed the bar by hopping on my digital scale that reads in 1/2 pound increments and the bar and hardware weigh in at 12.5 lbs for those debating in the previous posts.
goyogi is offline
Old 09-11-2006, 10:33 PM
  #62
jct
jct's Avatar
try this link
very simple install...
http://groups.msn.com/Sorensonbrian/...struction.msnw
jct is offline
Old 09-12-2006, 12:18 AM
  #63
goyogi's Avatar
Thanks Hornet, I just installed it using previous pictures and this link
http://www.whiteline.com.au/docs/ins...ar_general.pdf
I noticed that in the link you provided
that he has the washers reversed from the whiteline .pdf
Probably doesn't matter much. Also when I installed it I didn't replace the shock washers with the L bracket, i just placed it over the washer. The nut still grabs on all the nuts threads.
Took me a little over an hour to install. Not difficult but a little frustrating if you don't have it up on ramps.
Corners much closer to neutral on a few jaunts around the block. Once traffic dies down in a couple of hours I'll take it on the freeway loops to see how she fairs. I suspect the tires are the next weak point.
goyogi is offline
Old 09-12-2006, 04:01 AM
  #64
Music City Scions
bB2NER's Avatar
Default Re: Missing instructions
very easy job, just make sure you put the inner mounting points of th bar out near the corners as far as you can go but not past where the radius starts.
bB2NER is offline
Old 09-12-2006, 05:45 AM
  #65
goyogi's Avatar
I think I'm going to pick up the Energy Suspension bushing kit for the front swaybar(ENS-9-8122R ).
I know from another thread that I don't need the bolt and spacer that comes with the kit but I want to redo the rear swaybar links and use the bolt and spacer from the kit like Brian did here http://groups.msn.com/Sorensonbrian/...struction.msnw
as shown in the last couple of pictures.
I like the idea of a single bolt a spacer and a nylock nut, instead of a threaded bar, two nylock nuts and 2 regular nuts that comes stock with the Whiteline. Using the bolt and spacer from the Energy Suspension kit leaves alot less room for things loosening up and it's much easier to tighten the endlinks up to similar specs.
goyogi is offline
Old 09-13-2006, 03:54 AM
  #66
Big_Bird's Avatar
where can i pick up the whiteline rear swaybar?
seems to be my next mod
Big_Bird is offline
Old 09-13-2006, 04:58 AM
  #67
Music City Scions
bB2NER's Avatar
www.gtworkscom for the whiteline.
bB2NER is offline
Old 09-13-2006, 05:40 AM
  #68
Big_Bird's Avatar
it's something different
Big_Bird is offline
Old 09-13-2006, 03:42 PM
  #69
Music City Scions
bB2NER's Avatar
oops my bad.. its supposed to be www.gtworx.com. sorry,, been a while since i used it.
bB2NER is offline
Old 09-13-2006, 04:10 PM
  #70
Big_Bird's Avatar
oo dayum, thanks man, that is a mad good deal
Big_Bird is offline
Old 12-13-2006, 06:56 PM
  #71
Tamago's Avatar
did not read the whole thread but..
why not do both? whiteline AND progress :D
Tamago is offline
Old 12-19-2006, 02:50 PM
  #72
OrAnGeBoX's Avatar
I did put both on!
The ride is crap but the handleing is insane.
This addition was just what I was looking for and I am very pleased with the outcome.
Are there any other braces to buy?
OrAnGeBoX is offline
Old 12-19-2006, 05:08 PM
  #73
Music City Scions
bB2NER's Avatar
It shouldn't make the ride like crap. Unless you still had the stock shocks on and some really stiff springs. The bars only control lean.
bB2NER is offline
Old 12-19-2006, 06:22 PM
  #74
nnnickkk's Avatar
i want a whiteline so bad now haha.
nnnickkk is offline
Old 12-19-2006, 06:59 PM
  #75
Music City Scions
bB2NER's Avatar
It's one of the best bang for the buck mods you can do.
bB2NER is offline
Old 12-19-2006, 11:45 PM
  #76
OrAnGeBoX's Avatar
Well I have goldlines koni all around (on stiff) TRD rear frame brace, Progress, whiteline,Jic type1, hotchkis strut bar, Hotchkis front sway and a GTspec brace.
These things combined make for a rather rigid but fun ride
Old 12-20-2006, 12:18 AM
  #77
Music City Scions
bB2NER's Avatar
Domenick, That sounds like one very stiff set-up. Do you have and suspension travel when you hit bumps?I picture it riding like one of those 1/6th scale R/C xBs on a blacktop parking lot.
bB2NER is offline
AMS13
08-20-2015 07:26 PM
StreetStandard
07-06-2015 10:40 PM
TheScionicMan
105
03-23-2011 05:29 PM
ugly_duck
12
04-25-2005 10:42 PM
Back_In_Black_xA
09-27-2004 01:14 PM
Quick Reply: Whiteline Swaybar on xB
