will you rub on 185/ 60/ 15 with df210s
You won't rub. I was running 15x8 501's with df210's echo struts and a 5 mm spacer in the rear. I did get some rubbing but only on huge dips. The rubbing was so miner you couldn't even tell when looking at the tire.
Its pretty close. I think a 10mm spacer is better but then you will start having some rubbing issues. I had clamped the rear springs and lowered the rear some. With the 5 mm spacer on ther was no room between the tire and the lip of the fender. That tells me it was pretty flush.
