xb1 and xd suspension...?
how similar/dissimilar is the xD suspension from the 1st gen xB suspension...? can you reuse shocks? springs?
does anyone know? has anyone tried...?
Originally Posted by burstaneurysm
I wouldn't... the springs are designed for a certain weight.
I've said this a number of times...
Springs hold your car up! Do it right!
Lowering springs should use shortened struts with dampening set up just right for the weight of the car and the wheels you are using along with the proper bump stops. We also shouldn't forget that the weight of the car shouldn't change as that would completely throw off the balance of everything.
And let's forget about air springs altogether, there is just no way those will work. The rates are too variable as well as the ride height.
Originally Posted by Stylis
yeah the xD and xB are way different. I have been working on the xD suspensions for a bit and I have both springs out of both vehicles. Will not work.
Guest
Posts: n/a
yaris and xD share the way the strut mounts to the chassis . so just be altering a few things you can easily lower the front in about two hours time without even changing the springs.
rear springs are the same design on yaris , xd , and xb/xa , but they may be different diameter , and the spring rate will deff be different , how much so probably within a hundred pounds worth of spring rate.
unfort I think the xD is the heaviest of the bunch so you'd have to find decently stiff reafr springs off something else to make up for the added weight.
