16" tires - 195/50 - 205/45 - 205/50?
Ok I just picked up a set of 16x7's
What tire size should I run with my 2.5" Drop?
195/50/16 - 205/45/15 - 205/50/16?
I don't want too much meat, but I don't want them to look undersized and throw the speedo off.
Thanks!
Keith
Thanks!
Keith
I'm running 205/50/16 on my eibach pro-kit
Kit says it is 1.5inch drop, but seems lower. I have about one finger spacing in the back and 1.5 up front (fender lip to tire) and its fine.
I think the offset on the wheel will have more of a bearing on fiment
205-50 is the best in my opinion. 195 will look slightly stretched on 7in rim. And you may want to get tires with a rim protective rib even if you get 205's since the rim will stick out just a bit (that is if you want to be safe)
wonderworm
9
10-16-2003 07:14 AM
