17 inch rims on a xB?
Im thinking about popping on some Axis TC Evos. Was wondering if 17 would be an ok size. I am going to be driving A LOT (about 300-400 miles a week) and wanted to know if these would be safe to ride on. Also, i do not plan on lowering the vehicle.
i'm running 17s as well. with 215/45 nitto tires... although mine is lowered 2".... i have never scratched the bottom of my car. and i drive about 600 miles per week..although mostly on freeways to work..i live far from my work.
What is the width of your 17's. Does the large tire size throw off your speedo.
I.m runnin 17x7's 205/40/17 and thinkin about 205 or215/45/17's thanks
thanks to you guys, i'm also running on 215/45/17. no rub, and a little smoother ride than 40's(more wall).
http://www.miata.net/garage/tirecalc.html
speedo is off by 3.7%, on 60mph were actually traveling 62.2 mph, not much of a difference, i drive like a granny anyways(looking for potholes to avoid
Originally Posted by Ali La Pointe
well Nilo set me str8. I decided to go with 18's. What kind of tires should i get though? Im going to be moving to massachussetts so i know that when the weather gets going, im gonna have to ride stock again
Cheese
Originally Posted by rjsalvi
Do you have any rubbing anywhere when cornering hard? I assume if it works on a 2" drop, it'd be fine with stock? Thx.
i dont rub either with a 2 in drop, but now i may be selling my maglites, for a set of 20s.....i know i know, i always hated on dubs, but these are sweet, unreleased axis dubs in a 20 x 7.5, which "should" fit without rubbing
brent
brent
Im running a 215/45R17 as well, on a 40MM offset wheel too. I did have to fit a 3MM spacer on the front to clear the caliper, and i do have minor rubbing issues at full turn on the steering wheel. The rubbing is on the plastic inner fender, and will wear itself flush over time. BTW, im also riding with a 1 inch drop with the Tein H series, much better ride now over stock.
brent
brent
rvascion
11-12-2020 03:23 AM
