18x8.5 will fit?
Old 03-23-2004 | 02:44 AM
OKIHost's Avatar
Default 18x8.5 will fit?
I looked at the wheel guide and it looks like 18x8.5 will rub on full lock, my question it will they rub much more than say a 18x7.5 as it says they will also rub? Or am I better off just finding something that is 18x7.0?
Also if lowering does that make it much worse?
Thanks in advance.
Old 03-23-2004 | 02:47 AM
scionxb04's Avatar
huh??? 18x7.5 does not rub.....im running 18x7.5....offset front 45mm offset rear 30mm...lowered 1.8inch
Old 03-23-2004 | 02:50 AM
OKIHost's Avatar
Well it says the 18x7.5 rub in this thread here:
https://www.scionlife.com/forums/viewtopic.php?t=348
I am just looking from that, I would like to have 0 rub if I could but just trying to figure out what is most practical as this is going to be my daily driver.
Old 03-23-2004 | 02:53 AM
scionxb04's Avatar
if u look at that chart more closely
18x7.5 . . . . . . . 35 . . . . . . . . . . . . . 215/35-18 . . . . Front tire rubs at full lock
18x7.5 . . . . . . . 35-42 . . . . . . . . . . 215/35-18
an offset of 35mm will rub.....im runing 45mm front on a 215/35/18 tire....and 30mm offset rear....the tires are pretty even with each other and no rubbing front or rear....even withthe front tires at full lock
Old 03-23-2004 | 02:56 AM
OKIHost's Avatar
Ok so I need to see what offset I can get them in, I am looking at the ADR FUEL SILVER wheels from victoriatire.com so I will give them a call and see if I can get more info.
Thanks for the info I thought that meant all 18x7.5 and up would rub.
scionlife
371
06-02-2015 11:00 PM
yardleyTC
03-06-2015 10:03 PM
Klutch_Wheels
Scion tC 2G Wheel & Tire
12-31-2014 06:16 PM
Quick Reply: 18x8.5 will fit?
