19" wheels help
19" wheels help
I did a search on 19" wheels and seems like some have rubbing and some don't . my question is: will 19x8, 40offset with 215/35/18's rub with a 2" drop? seems like some say they do and some say they don't, some say they rub only when turning all the way to the left or right. My question is which one is correct? will they rub?
thanks for all your comments.
they should be ok, i would guess that youll beed to run a 5 mil spacer on the rear, and the front shouldnt rub at all, maybe only at full lock in a u turn or so. the spacer will only be required if your back tire rubs the trailing arm, if it doesnt you should be cool
brent
brent
brent
brent
Re: 19" wheels help
so what setup will you guys go with for 19's "Without Rubbing!"
18x7.5 or 18x8's wheels? and what offset?
215 35 19's or 225 35 19's tires?
how many inches to lower? 1" or 2" ? and what springs do you guys recommend?
I would be thankful if all can assist. :D
evolving_machine
10-21-2023 01:16 PM
kleecker
Scion xB 2nd-Gen Wheel & Tire
05-22-2016 06:10 AM
