19x8 with 35MM Offset abd 235/35/19
I want to run the Axis Hagen wheels which are 19x8 with an offset of +35MM. Will these wheels sit inside the fender well and not stick out? I don't know what the proper offset is for the TC. Tire choice would be 235/35/19 unless I could go with a 245/30/19.
I'm running Axis Hiro's in 19X8.5 35mm offset with 2253519 Toyo Proxes lowered with H&R Springs. Very slight rub on hard dips in road and only when it wants to. It doesnt rub all the time. Check out my pix.
http://www.cardomain.com/id/05tc916
OK the OE rims for the tC are 17x7 with a 42+mm offset
At stock height, the tC is very generous with the wheel side clearance unlike Subaru (subaru WRX onwers know what i mean...no offense)
my suggestion would to go with anything close to the 42+ i highly recommend a 45+mm offset for a 8" width rim. in that case you will have a side clearance much like stock.....in otherwords it CAN tuck if you want it.....but consider the negative camber though.
as for the wheels.....19" rims are huge for the tC but looks very nice
the OE potenzas specs are
215/45ZR17 -- 7.0(tested rim width) 24.8(overall diameter--inches) 839 (rotations per mile)
235/35/19 -- 8.5(tested rims width) 25.6(overall diameter--inches) 813 (rotations per mile) way to big!!!!!
The idea is to have a wheel diameter within 1% size comparision between the two wheels for 2 reasons: 1)perfomance.....the bigger the wheel,less perfomance....and 2) the odometer mileage wont be as off.
I recommend
225/35ZR19 -- 8.0 (TRW) 25.2(OD) 824(RPM) its smaller and more aggressive looking than the 235/35/19....but comes with a price........in order to run these puppies is to have extremely STRONG rims
hope that helps
I recommend
hope that helps
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
02-29-2016 05:39 AM
umnitza
09-01-2015 08:06 PM
