View Poll Results: Do you rub at all?
Voters: 11. You may not vote on this poll
215 45 17 Official Thread.Please Post 215/45/17 Tires!update
I was doing a search, at the moment I was looking to actually see how a 215 45 tire on a 17inch wheel would look like.
So if you have pics!! Show em off!
I want to see how porportionate the tire is to the rim.
So please post your pics and hopefully answer these 3 questions.
1. Width of the actual rim. (7.0",7.5",8.0",...) ?
2. Offset of the rim. (et40,et38,et35,...) ?
3. If your car is lowered..or stock... if lowered,how much? (1",1.5",1.7",2",or2"+)
I have been seeing a lot of threads about this one tire size. Yet a lot of them do not have pics. So this one thread will hopefully eliminate a lot of people's questions.
Thanks in Advance
Also I you can post threads of this topic to have a sort of data base of this topic.
Here are some topics I did a quick search.
https://www.scionlife.com/forums/vie...&highlight=215
Here are some links of members w/pic with this tire size.
https://www.scionlife.com/profile/jethro_b 17 x 7 - et40 - 1.5" Lowered
https://www.scionlife.com/profile/Stealpulse 17 X 7.5 -et35 - 1.6"F 1.5"R Lowered
https://www.scionlife.com/profile/stick_1NZ 17 x 7 - et42 - 2" Lowered
https://www.scionlife.com/profile/Lonely_Raven
http://www.sounddomain.com/ride/2052640 Added 2/9/06 17x7 - et42 - 1 3/8"F 1 5/8"R Lowered - No Rub.
https://www.scionlife.com/profile/Denstyr 17 x 7 - et40 - 1.06"F .91"R Lowered
https://www.scionlife.com/profile/Dwestxb Added 2/8/06 17x7.5 - et40 - 2" Lowered - No Rub.
https://www.scionlife.com/profile/CBSIMONSEZ 17 x 7.5 - et35 or et40 - 2" Lowered
https://www.scionlife.com/profile/Sid_xBicious Added 2/11/06 17x7 - et40 - 1.7"F, 1.5"R Lowered. 5mmF 10mm"R spacers.
Thanks in Advance
I agree, Great Thread!
OK, so their are many pics of the exact same setup I want to run,
only problem is that I have an XA not an XB.
I want to run 5Zigen FNO1R-C 17x7 +42 with 215/45/17
Stock, not lowered.
Is that setup possible with No spacers, No rubbing, and full front radius?
PLus, since this is what this thread is about, post pics of your XA if you have them.
Stock, not lowered.
I believe the xA and xB drive train and suspension are the same .
The green xB above is running that setup. He hasn't mentioned any thing about rubbing. I believe you will loose some turning radius considering its 2.3% bigger than stock.
