225/35/17 Will they rub?
I think they will scrub forsure, I mounted that size on mine from a buddies car because i wanted to run that size tire, and they rubed like hell the rims were 17x8 and I think a 35 offset I bet if you run 215 you will get a good stretch, or 205 45 will even be better but lot less rubber, I run 205 /40/17 on mine and the rubber is thin but I like the look and it rides pretty descent , but I watch out for potholes forsure to protect the rims , Im also lowered on Tein Tech S springs ,
Hope this helps, Russ
when i do get rims on my car which will be a while cause the current tread is still pretty deep. i was looking at 17x7.5 w/ a 38mm offset wrapped in 215/40/17 and i have done some research. its really really close to stock diameter. i m just hopin i wont have problems w/ rubbing
amazing converstion tool:
http://www.1010tires.com/TireSizeCalculator.asp
Yakimaniac
Scion xD Wheel & Tire
11-22-2014 04:20 PM
