Help in a bind (I did a search)
Guest
Posts: n/a
I have done a search and havn't come up with the answer i need to find...so here it goes....I would like to run 17x7.5 et42.....what size tire and spacers do I need to use so these fit with a the trd shocks/spring combo? any help on these would be great thanks
brian
brian
Originally Posted by xBofMNx
do you know how the wheels will sit tucked or flush or inbetween
plus i would like to use a 45 series tire what size would you all recommend
In terms of using spacers I believe anything smaller then a 36 offset requires a spacer and longer studs
dude you're on point. so whats really good? you got some typical civic wheels in mind? to answer you question the lower the offset the better. 17x7.5 needs 35 rear and 40 in front with 5 mm spacer.
