HELP!Installed OTG spacers and now wheels wont move. SOLVED
>>>----SOLVED----<<<
I used the bolts that shipped with the OTG spacer kit. The bolts were much longer than the original ones. What happened was that one of the bolts was interfering with the operation of the brake pad. The bolt was so long it was blocking the pad from moving. I solved the problem by using washers to "shorten" the bolt. The pad now has clearance to move properly. Hope this helps if anybody else has this problem.
Originally Posted by smokeydog001
Did you install 1 set of the 3/8" (9.53mm) thick shims or 2? Did you use the lock washers supplied with the kit?
Beesh
01-09-2015 06:30 PM
