hub spacers.
Old 07-29-2008 | 10:04 PM
bB2NER's Avatar
Music City Scions
You need 1/2" ones to be exactly even according to the track widths given by Scion. Plus Mikes come anodized black so they won't corrode like the OTG ones I had at first.
Old 07-29-2008 | 11:22 PM
BlackYaris's Avatar
plus mike has a hella-better price
Old 07-30-2008 | 01:22 AM
AllianceAutoSports's Avatar
Music City Scions
Hello, I am Mike. Some of you know me from the rear brake conversion, and some from these spacers. (soon to be much more) I have four spacer sizes available. This eliminates the stack method to get the correct offset needed. The 1/2" spacers will even the rears up with the fronts as Jeff has mentioned. Here are the size conversions.
1/4" = 6.35mm
3/8" = 9.5mm
1/2" = 12.7mm
3/4" = 19.5mm
Spacers come anodized black! The hardware in the 1/2" and 3/4" kits are 10.9 automotive grade bolts and washers. The 1/4" and 3/8" are 8.8 grade bolts, and 10.9 grade washers. PM me for more details!
Old 07-31-2008 | 05:17 PM
elusivebb05's Avatar
Just installed Mike's 1/2" spacers last night. Love the way it looks now.
Only concern is that my parking brake cables seem to be stretched a little tight (I know it's because of the extra space) but, I was wondering if anyone else had them chafe or start to rub through the coating on the parking brake cable.
Thanks.
Old 07-31-2008 | 06:01 PM
bB2NER's Avatar
Music City Scions
No prblem with my e brake cable. It will settle in with time and be fine.
Old 07-31-2008 | 07:06 PM
Music City Scions
Thanks.
I personally have been running the 1/2" spacers for about two years with no problems.
Old 08-01-2008 | 05:23 AM
Good to hear. So far I love the look! An alignment will be needed though. The rears are a bit negative.
Old 08-01-2008 | 05:25 AM
bB2NER's Avatar
Music City Scions
Being a solid rear axle I don't think the rear alignment is adjustable. Mine is 4 years old and has never needed an alignment yet.
Old 08-01-2008 | 05:42 AM
greybox's Avatar
No way to camber adjust-make sure your bolts are tight-if they are loosening (the bottoms) it would give camber and a HUGE problem down the road.
I run the 1/2 inch ones as well as 5mil wheel spacers and have no problems. 215/45-17 tires-I think my wheels are 40s offset (Konig tantrums)
Old 08-01-2008 | 05:52 AM
bB2NER's Avatar
Music City Scions
I agree. He should re torque them after a hundred miles or so just to be safe.
Old 08-01-2008 | 04:48 PM
Music City Scions
Agree^^^ As far as the spacers go, they have no camber in them. So check and re-torque the bolts. Thanks, Mike
Old 08-01-2008 | 05:37 PM
Yeah I know about it being a solid axle and not being adjustable. They are probably fine but, just look negative haha. I work in a shop so I can get the alignment done for free anyway so... why not.
Old 08-01-2008 | 09:37 PM
kms_tuning's Avatar
I know with 10mm spacers you'd definatly need new studs, but would you new new studs with 5mm spacers?
Old 08-01-2008 | 10:20 PM
bB2NER's Avatar
Music City Scions
We are not talking about spacers that go between the wheel and hub.
Old 08-01-2008 | 11:44 PM
greybox's Avatar
If that's in reply to my post-no, 5mm wheel spacers are the widest you can add without any stud altering (and I am not sure I would do that on the front due to the torque possibilities)
Old 08-02-2008 | 05:49 AM
magicmanjk808's Avatar
actually, i was running 10mm spacers without extended studs for 7 months. no problems there. definately not for the faint of heart though. i did get extended studs, i just never installed them.
Old 08-19-2008 | 02:58 PM
Bdiddy's Avatar
My wheels are 17x7 with a +38 offset, which size spacer would be best for me? I don't know anything about offsets and such.
Old 08-19-2008 | 06:37 PM
Music City Scions
I run the same size wheels and offset on my xB. I ran 1/2" Spacers on mine and had no problems rubbing. I am also on S-techs. The 3/4" will with a load, if your lowered. The 1/2" ones will flush them with the front tires. PM me if you need some.
Old 08-20-2008 | 02:28 AM
Bdiddy's Avatar
I am lowered on s-tech springs as well.
So I will go with the 1/2 inch when I get some extra cash. Thanks for the info.
Old 11-22-2022 | 02:54 AM
Jomar2626's Avatar
Default Hub spacers for xb 1st gen
Hi do you still making the scion xb hub spacers? I wants to know the price or where I can go to buy them?
Quick Reply: hub spacers.
