"I NEED HELP WITH TIRE AND RIM INFO"
hello, i am getting an xA and i need some information. as everyone is well aware of the xA comes stocked with 15's. I am getting hubcaps because the alloy wheels scion offers are not very attractive. Can i put 17's on this model without there being any problems? I don't want it to scrape or anything. If so what would i need just 17 inch wheels and tires. Because you can order them offline as a set.
If not, or say i wanted to stick with 15's, will all 15 inch rims fit the factory tires or would i have to get new tires also. Please help me![/b]
Hey man,
Congrats on the xA. Just to let you know, the answeres to all your questions are located in these forums somewhere. Just use the little red "search" tab above or simply browse the xA/wheel & Tire forum.
You can most def. put 17's on your car without any problem, and if you wanted to go with a 15 inch wheel, you could even save some money by using your stock rubber.
If you don't plan on slamming your car or running crazy offsets you should be fine.
Even if you wanted to do a nominal drop, you will still be alright , but do a search, read up on it and good luck.
Matt
Matt
Yakimaniac
Scion xD Wheel & Tire
11-22-2014 04:20 PM
Besk_one
10-18-2003 08:41 PM
