I NEED SOME HELP ASAP!!!!!!!!!!!!
WATS UP GUYS I SEARCHED AND YA TAKES TO LONG HAHA OK HERE IT GOES
IM GOING TO BE GETTING MY XXRS 501 RED THERE 16X8 FRONT AND BACK BUT I NEED SOME HELP ON THE TIRE SIZE I HAVE THE DF210S 2. 5 FRONT AND ABOUT 2 IN THE REAR
HELP HELP HELP
HELP HELP HELP
ive got the same wheels with the same drop. about to put on some 205/45/16 soon and hopefully rubbing isn't too bad. a little fender rolling should do the trick though. but i'll have to see. let me know what tire size you end up choosing.
ive got almost the same setup (sportmax 501 16x8+15 on tein coilovers, dropped about the same) and im running 195/50/16
but even with a 195 i was rubbin bad (only in the back) with anything in the back, i even had to adjust my coilovers up.
what i had to do to get rid of the rubbing was -3 camber and roll the rear fenders.
if i turned the strearing wheel all the way i would rub a very tiny bit on the drivers side only and i just did a few taps with a hammer and i went away.
this is after tire / wheel install with out camber or rolled fenders
then i did -3 camber
this help alot but it still rubbed if i had stuff in the back and went over a large bump.
i don't like rubbing so i decider to roll the fenders too.
this with the back loaded full, no rubbing, ever
