nitto neo gen?
nitto neo gen?
anyone have these yet?
i'm deciding on tires for my new 16" rims and can't decide between a set of potenza re730's (discountinued tire, but had em before and loved them + only $75), neo gen's for $79, and of course the good ol' kumho 712 for around $80 a tire.
one thing i noticed is that the neo gens in 16" are only "V" rated (same as the kumho's), not "Z"... i'm leaning toward the re730's since they are full "Z" rated.
opinions? other tire in this price range?
the guys at spy motorsports (scioned.com) were really big on the nitto neogens versus the kuhmo 712's. and they sold them both at pretty much the same price. they told me that the kuhmos wear too fast. If nothing else the neogens have a sweet tread pattern. Hopefully someone has ACTUAL experience to actually help you.
please let us know what way you go.
your car will never go 180+mph (...well unless you strap a rocket to the back), so there's really no need for a "z" rated tire
in fact since our rides barely push 120 you should be fine with "h" rated tires
thanks for the comments...
as far as the "z" rating comments of never going 180... yes of course i won't. however the speed rating often tells you more about the tires then the top speed. z rated tires are in most cases higher performance tires in all aspects, not just top speed. you show me a "h" rated tire that handles as well as ANY "z" rated tire and i'll listen to your arguments.
anyways, back on topic:
hnefrdo - yeah i know they are all seaon and if it's possible to have a performance tire that is M+S rated, then great... that's what i'm trying to figure out. if they are not truly a performance tire, just a good looking, decent performing all season tire, then i'll get the potenza's.
SCI FIRE- can you elaborate? how do they handle in comparison to other performance tires you've used (perhaps on another car?). do they seem "sticky" or do they squeel around corners?
Well, I don't drive like a maniac or anything, lol, but they stick... no squealing or chirping, so far. There hasn't been much rain here, so I haven't been able to see if they hydroplane.
I've had my nitto Neo Gens for a couple of weeks and 3000 miles, and I love them... definitely good grip, I've had to push hard to make them chirp and in the rain they handle just as good... V rating or not, they've proven to me to be damn good tires... no extra road noise and at a 205/45/16 they feel good on my Eibach Pro Kit springs...
2fixA - thanks for the response! got a question for you about size.... i see you are running 205 45 16's... what made you choose the smaller diameter over the 205 50's? i'm going through this decision right now...
umm take a 90 degree turn going 60 MPH.
try H-Rated tires..
then try W.. then Z..
notice its no where near 180mph but theres a difference.
just like rims..
u can't go half ___. u get what u pay for.
the phrase was made for a reason. USE IT!
as for neo-gen;s.. i give them 2 thumbs up.
i guess hit up spy for a deal if u can.
neo-gen's have a harder compound in the inside
of the tread so that lowered cars with camber will wear LESS
on the tire cuz its harder there.
try H-Rated tires..
just like rims..
i'm so glad this topic came up. i'm planning on getting some AXIS wheels and i wasn't sure what tires to get...or even know how to decide what tires to get.
Can some one please explain how the rating system works
So what i gather is there are speed ratings....from ??? to Z....Z being the highest rating
There is a treadwear rating...what is the scale? i assume this would be important to me because i commute way too far every day
There is a traction rating...what is the scale?
I assume i want all season tires here is socal?
Finally where do i find all the ratings for different tires?
Wow...sorry so many questions.
Thanks!
aimee
Thanks!
aimee
Neo-Gens are cool, im running on 215/35/19 and the best things about this tire is that they are asymmetrical, so unlike directional z rated tires they can actually be rotated for longer life .
Our dealership in San Diego runs Nitto Neaogens in 17, 18, 1nd 19" on our aftermarket wheel packages. I like 'em. They ride nice, not a lot of crazy road noise, and they can be rotated for longer life.
werd
werd
i dug up some specifics for ya:
ratings go from N(87mph) - Y(186mph)
they indicated the fastest speed you should travel on the given tire. of course they mean a lot more then just top speed; a Z rated tire is built to be more performance oriented then an H or even a V tire. hence the Z rated tire will perform better in all aspects of performance (handling/stability/etc...).
W and Y are just Z rated tires that are further rated for higher top speed.
more info here:
http://www.tirerack.com/tires/tirete...eral/speed.htm
treadwear is suppose to show the life of the tire relative to others. usually the higher the performance, the softer the tire, the LOWER the treadwear number and the shorter the life of the tire. most max performance tires are in the 200-300 range. these tires from my experience last anywhere from 10k-40k miles depending on your driving habits. since you commute long distance, you might want to look at a tire that has a good compromise between peformance and treadwear; or you might not care about performance that much at all, and just get a touring radial with a larger treadwear rating.
more info: http://www.tirerack.com/tires/tiretech/general/utqg.htm
C-B-A-AA
AA being the best, but only better then A in wet breaking.
no. i live in socal as well and i'd say its one of the few places i would want a 3 season or "summer" tire instead of an allseason since we don't get snow on the ground. if you are concerned about performance in rain, just make sure the tire has good "hydroplane" resistance. all seasons are only needed if you encounter snow or ice... which we definately don't have in socal. the only thing they will do is hurt your dry performance.
go to tirerack.com... just put in the size your looking for and when you pull up some of the tires they will have the ratings listed under "specs".
here's and example (and a tire that would be great for your situation):
http://www.tirerack.com/tires/Spec.j...=Potenza+RE750
no probs. thats why we're here.
more info here:
oh and also, on their website, they list "AA" for traction, but at discounttiredirect.com they are only "A". anyone actually know what they are?
