offset quesion
offset quesion
I'm looking at a set of wheels( 15X 6.5 , +45 offset, 4X100) . Will these wheels work fine... or will I need to modify(spacers??) something ? This would be on a 2006 xA
Thanks in Advance.
Thanks in Advance.
45mm seems like a high offset, I am somewhat sure you will need spacers. I run 15x6.5 and a 40mm offset, and I don't know how close I am in the front, but in the back, I am only a millimeter or two away from the bolts on the rear torsion beam. You might one to invest in some OTG rear hub spacers or something.
So.. I'd probably then need at least a 5mm wheel spacer in the back then- is what it sounds like.
Anyone else ??
Thanks.
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
02-29-2016 05:39 AM
umnitza
09-01-2015 08:06 PM
